Photos 67 Resto Mod LS6/6Speed
Slid rear of frame under car with jack,chain hoist was slipping and couldnt get car up any farther
Center console i molded off stock one and moved shifter and trimmed it with 1/2x1/2 angle iron and smudged it together.
Received 1,762 Likes
there where alot of repairs underneath so i ended up taking the DA
to the underneath and other areas hand blocking,looking back should have painted it the color of the car.Firewall had a large hole where it looked like they drilled with a hole saw to get to a bell housing bolt and a couple 1/2 cracks.They also had cut a hole above differetial to remove
the differetial without removing the crossmember.It looks good.
67 corvette Marina Blue was a little dark for me so this was painted
67 Chevelle,Nova,Corvair Marina Blue its actually a little lighter than
the Corvette at least on the paint chips,and 2003 Arctic White Stinger
#34
I trust him he has worked at a dealership and ran his own
Body shop for years.If it ain't perfect it won't leave there.
He painted my Split Window and did some blending due to some
Scratches on my 66 did an awesome job.
We will see
We will see
#36
I know there 17x7 with 4inch up front with 225x50x17
Back when I started this build I knew everything first hand I will run thru my receipts tomorrow if I can't find it I will call New Nostalgia Wheel
And check .Vansteel product is nice and Dan is awesome guy.Will have answer tomorrow and rear wheel size
#37
You know it's guys like you,that guys like me won't join the local vette club
Negativity,shouldn't type anything your not willing to say in person?
Of course everybody with a mouse in there hand is a Know it all and and
Rambo
By the way to the guy that wanted to know the wheel size I called
New nostalgia. The rears are 17x8 with 51/4 back spacing mounted
On 255/45/17 hope this helps
Rambo
#40
My buudy who is head of R/D in the cylinder head dept for Richard
Childress is coming in tomorrow night so im syched to show him
it should be sanded and buffed????
