Balance Question(s)
Old Feb 28, 2012 | 05:01 PM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Default Balance Question(s)
I'm currently working on my '65 El Camino which has a fresh 327 (.0030) over and lots of good parts) suppose to be built to 350HP specs. I also have original 327/365 engine that goes with my '65 Vette.
The El Camino has a small 6" pressed-on balancer and the Vette has larger bolted on balancer. (see photos below) El Camino 327 crank is not tapped for bolt.
Question 1: Can the larger balancer be used WITHOUT being bolted? If so other then timing tab what else do I need?
Question 2: Will it make a real difference for just normal street/cruising driving?
Question 3: El Camino does NOT have space behind balancer, what is the thickness of the spacer?
I know its really a damper but old habits are hard to break.
George
Old Feb 28, 2012 | 05:47 PM
midyearvette's Avatar
midyearvette
jmo.....i would drill and tap the snout for a bolt, very easy to do.
you can decide which balancer to use but the correct timing cover/tab is also an issue....
Old Feb 28, 2012 | 05:53 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
I'd probably drill and tap the crank for safety, but leave the balancer on it. If it was professionally balanced, it was done with the balancer and the flywheel as well. Why mess with it?
That being said, yes you can just press on the bigger unit, I've done it a few times with no problems ever. You just need a new pointer and you can buy one that mounts to the timing cover bolts, and cut the old one off if you don't want to change covers. Change the seal though!
Old Feb 29, 2012 | 08:17 AM
Black_Magic
Thanks for the info --- I decide soon what to do
George
Old Feb 29, 2012 | 07:04 PM
claf's Avatar
claf
Q2. Either balancer will work. Bigger balancer will VERY slightly make getting going easier (like adding a couple pounds to the flywheel) if you have an engine with low torque at low revs.
Q2. Not positive but somewhere near 1/8", same thickness as a C1 front motor mount. Used to get the crank and WP pullys lined up. Bob
Old Feb 29, 2012 | 07:14 PM
JohnZ's Avatar
JohnZ
The 1/8"-thick spacer is ONLY required on a C1 installation, to compensate for the thickness of the motormount bracket.
Old Feb 29, 2012 | 07:16 PM
pop23235's Avatar
pop23235
Either dampner can be used on the 327. I believe i remember that the smaller on gets the first two harmonics and the larger on is required for the 3rd harmonic on the crank as it is rated at much higher RPM than the smaller one.
I would not drill and tap the CI crank unless you remove it and do it in the machine shop. Millions were not tapped and worked flawlessly.
Unless you're taking the smaller damper up to 6K RPM regularly you don't have a problem with using it.
Old Feb 29, 2012 | 08:57 PM
midyearvette
wow!!.....such an easy thing to do with the engine on a stand and the benefit of peace of mind....
i really can't understand your logic.......
Old Feb 29, 2012 | 09:36 PM
pop23235's Avatar
pop23235
Well I didn't answer the OP's questions completely. I would not put the big damper on the smaller engine.
I would not drill and tap the crank in the engine because you cannnot align the drill with the crank centerline accurately. Drill it wrong and it will either vibrate, break the crank and or likely require replacement. That crank is Cast iron, not forged steel. Get some wobble out on the end of that shaft with lots of metal removed is dangerous. You cannot hold a drill in mid air. Any thoughts on why it isn't already tapped?
Granted, if the bigger damper, or even the smaller one could be easily bolted, that would be preferred. I would not try the larger damper without a bolt. If you can make a tapped hole exactly on the centerline, proceed.
Old Mar 1, 2012 | 07:24 AM
midyearvette
speak for yourself guy, on what you can and cannot do....
maybe i should send out a re-call on the dozen or so i have done over the years "freehand" with great results, especially on nhra sanctioned drag cars...........
Old Mar 1, 2012 | 10:42 AM
pop23235's Avatar
pop23235
Ya know, I'm on a few boards and they have mostly good people having fun and helping out. This board has the largest collection of know it all *******s with smart *** attitudes of any I've ever visited. Think I'll move along. You guys deserve each other.
Old Mar 1, 2012 | 11:59 AM
midyearvette
don't let the door bother you on the way out, not everyone can make the grade of knowledge and experience that's required on the "darkside".......too bad you are leaving, you might have learned sumpin'...
Old Mar 1, 2012 | 02:24 PM
66since71's Avatar
66since71
Give Pop a break. He's right about the correct way to nose drill a crank, and seems to understand a little about dampers. I learned something! These are actually pretty robust machines we play with so you can get away with a lot of approximations/short cuts. But if you want to do it right...
Harry
Old Mar 1, 2012 | 03:03 PM
midyearvette
Harry
give me a break harry, maybe i can hold a drill a lot better than pop?? i am sure that other c/f members have drilled for these balancers too.
he didn't have to direct his brash comments to me or other c/f members, wtf/ we are all here trying to help out or learn other proven techniques..... it is a simple job to do and it won't take anything out of balance or create a wobble, if you really go bubba on it, i guess anything is possible.......peace and harmony i say, life's too short.....
Old Mar 1, 2012 | 06:33 PM
66since71's Avatar
66since71
Harry
To Balance Question(s)
