Differences between 326 and 609 pump?
Old Feb 29, 2012 | 06:33 PM
Fawndeuce's Avatar
Fawndeuce
Default Differences between 326 and 609 pump?
I understand that the 326 water pump came after the 609, but what are the actual differences between the two?
Paul
Old Feb 29, 2012 | 07:55 PM
JohnZ's Avatar
JohnZ
Paul
Internally they're the same; the 609 pump was used on base engine applications (no bypass hose to the intake manifold), and the 326 pump was used on SHP engine applications - it had a drilled/tapped boss at the top for the intake manifold bypass hose fitting.
