Need Some Help
Old Mar 6, 2012 | 09:14 PM
warrenmj's Avatar
warrenmj
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Default Need Some Help
I finally got my '66 L79 back in shape (or so I thought)and the weather today in Colorado Springs was in the upper 60s so I drove it to work. I drove it to my office approx 18 miles, then a few hours later drove it another 10 to the USAF base that I primarily work at. Everything was running great. When I started to drive after work, I got maybe a quarter mile and started to hear a rattling coming from under the car. I quickly pulled into a parking lot, opened the hood to see what was going on. What I saw was the harmonic balancer slightly wobbling, which was also creating the noise. It was too late to get a tow truck to the base, so it is safely behind the fence of Schriever AFB until I can get it on a flatbed tomorrow, hopefully before the snowstorm hits. I would appreciate any thoughts or ideas at what problem I am looking at.
Old Mar 6, 2012 | 09:18 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Was the bolt in the ballancer
Old Mar 6, 2012 | 09:20 PM
Vega$Vette's Avatar
Vega$Vette
Is the balancer coming apart and wobbling or is it loose on the crank and wobbling?
Old Mar 6, 2012 | 09:24 PM
warrenmj's Avatar
warrenmj
I'll check both of those in the morning. I was in a suit and tie and it was starting to get dark so I couldn't see all that well. I'll report back tomorrow on what I see.
Old Mar 6, 2012 | 09:38 PM
66jack's Avatar
66jack
If you need a new one or want your "stock" correct one, refurbished/rebuilt. These 2 places will do it..I bought one for my car from the first one here...
http://www.damperdoctor.com/
http://damperdudes.net/
Old Mar 6, 2012 | 09:43 PM
henry63's Avatar
henry63
This place is awesome, 24 mins. after posting, 3 replies with help!
Old Mar 6, 2012 | 09:44 PM
62Jeff's Avatar
62Jeff
If your car has the center crank bolt that is supposed to be there on an L79, the bolt could be loose or the balancer could be coming apart at the vulcanized ring.
If your car has a press-on balancer, the crank snout or balancer surface could be damaged allowing the balancer to come loose, or it could be coming apart at the vulcanized ring.
Good luck
Old Mar 7, 2012 | 11:07 PM
warrenmj's Avatar
warrenmj
The bolt was still in the balancer, but I wasn't able to really check it out today. I did get it to the shop and should have a good read on it in the next day or so.
Old Mar 8, 2012 | 09:09 PM
warrenmj's Avatar
warrenmj
Pulled the harmonic balancer today and it had a 3/4" crak on the "collar" that gets pressed onto the crankshaft. The crank looks fine, so it looks like I just need a new balancer and I should be good to go. Question: What would have happened if the balancer had come apart and come off the crankshaft while the engine was running?
Old Mar 8, 2012 | 09:24 PM
62Jeff's Avatar
62Jeff
It could have:
  • taken out the radiator
  • taken out the hood
  • bounced around in the engine compartment making a mess
  • possibly all of the above
Old Mar 8, 2012 | 09:27 PM
Lou64's Avatar
Lou64
I don't really think its immediate death or anything. After all the harmonic balancer is just a way to keep the engine from vibrating uncontrollably. This might give you a front end wobble/vibration since it wouldn't be functioning. The belt would be thrown, so you would likely start to overheat with no cooling happening assuming you didn't notice it. You would also probably get a horrible rattling sound of which you got a taste of before you parked it.
My first car was a Mustang and it got a harmonic balancer problem that was not worth fixing as the car was worth 1400 bucks. It sounded like a diesel.
Old Mar 8, 2012 | 09:29 PM
erb64's Avatar
erb64
You could shoot your eye out with that thing flopping around,glad damage was a minimum.
Old Mar 9, 2012 | 08:47 PM
warrenmj's Avatar
warrenmj
I think I was very lucky. I was doing about 25 mph when it went from a smooth running quiet engine to a minor rattle to a loud noise in a matter of less than a minute. If it had happened 10 minutes later, I would have been on the highway doing 65 mph and probably would not have heard a thing until it grenaded.
Old Mar 9, 2012 | 09:14 PM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Count your lucky stars!
To Need Some Help
