63 Speedometer problem
Old Mar 9, 2012 | 09:35 AM
Montana Mike's Avatar
Montana Mike
Default 63 Speedometer problem
Hoping someone can suggest where to look for correcting a speedometer which is reading approximately twice the speed the car is going? The transmission is a 4 speed Muncie.
Old Mar 9, 2012 | 09:52 AM
Dave Tracy's Avatar
Dave Tracy
Wow, 140 in a 70mph limit! All joking aside, have you done any work on the dash cluster or transmission? There is an adjustment on the speedometer itself.
Old Mar 9, 2012 | 10:33 AM
Montana Mike
It's no double talk when I say the car is really racking up the miles! I will check the adjustment on the speedometer. No work has been done on the dash cluster or transmission that I am aware of, however the car is fairly new to me.
Old Mar 9, 2012 | 10:43 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Is this the first time you noticed it? If so, the wrong speedo gear may have been put in the trans. The correct gear is determined by which trans and rear gear you have. Dennis
Old Mar 9, 2012 | 10:59 AM
Montana Mike
Well, yes, yesterday was the first time I had really driven the car as I was awaiting insurance and licensing. I'm guessing the only way to know if it is the correct speedo gear is to pull it from the tranny?
Old Mar 9, 2012 | 11:05 AM
Bluestripe67
Mike if you can determine the rear ratio I can look up the proper number/color gear for you. Dennis
Old Mar 9, 2012 | 12:52 PM
JohnZ's Avatar
JohnZ
It's virtually impossible for a speedo to read twice car speed due to a wrong speedo driven gear; there isn't anywhere near that range of difference in tooth count in the available gears. You have a calibration issue in the speedo head itself - it needs to come out and be checked out/rebuilt by one of the speedo restorers.
Old Mar 9, 2012 | 06:30 PM
mait's Avatar
mait
6th Gear
Did the car come from Canada? When Canada went metric (in the early eighties as I recall) some FLAPS sold adaptors that increased the speedo cable RPMs by 1.6 so the speedo would register KPH instead of MPH.
These units usually mounted right behind the speedo head. Check and see.
Mait
Old Mar 10, 2012 | 12:13 AM
Pilot Dan's Avatar
Pilot Dan
Most likely the adjustment spring has sprung.
Old Mar 10, 2012 | 11:05 AM
Montana Mike
Pulled the instruent cluster and there is only the cable going into the back of the speedo. So appears you guys are right....must be inside of the speedometer. Thanks all for your help.
Old Mar 10, 2012 | 11:13 AM
32361ARTHUR's Avatar
32361ARTHUR
I thought mine was doing the same thing but I found out when I got the speeding ticket that actually it was correct!!
To 63 Speedometer problem
