Help with steering
I put the steering on today and the driver side tire is throwing me off. When everything came off nothing was touched so I want to make sure I am not doing something wrong before going any further in putting everything back on. I know that things can be adjusted but just want to make sure nothing is amiss.
Not sure if these help or not. Any help greatly appreciated.Thanks Jim
How much of the suspension did youi have off? Looks like there is too much positive camber on the drivers side. Does it have an offset shaft on the upper control arm? Maybe it's on backwards? Are the alignment shims back in the same place?
I did not put the shims that were originally on there back on. I figured it would all be off since the frame and everything was powdercoated. I actually didnt even think about the shims but it looks like it is still too much even if the shims were in place. I believe everything was put back together correctly. Jim
the tie rods are in the same holes but you are correct the threads are not equal. So is this an easy fix? I am not familiar with this stuff so I am going to go out on a limb and say I would have to do is adjust each tie rod until the tires lined up right?? or that would at least get me in the ball park?? Thanks Jim
