Strange old technique.........
Old Mar 19, 2012 | 11:13 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Default Strange old technique.........
I've never, ever heard of this way to clean carbon out of a motor!
Old Mar 19, 2012 | 11:23 AM
C6Matt's Avatar
C6Matt
must have a way for the air to escape... position engine with exhaust valve open perhaps?
Old Mar 19, 2012 | 11:26 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
i've heard of walnut shells through the carb with the engine running, but the favorite was water with a bit of soap for lubrication poured into the carb with the engine running at a couple of thousand rpms..
Bill
Old Mar 19, 2012 | 11:47 AM
Kerrmudgeon
Bill
I've done this before Bill, and it works great. An old mechanic showed me how. You start with a hose on dribble in the carb at idle and gradually increase the rpm and water at the same time until you are at wide open throttle and a large stream of water going in! You should see the black smoke from all the carbon that spews out the tail pipe, it's amazing.
Steam cleaning from the inside.
Old Mar 19, 2012 | 12:10 PM
INMYBLOOD's Avatar
INMYBLOOD
From: The problem is all inside your head she said to me.
This may be the origin of the term "Rice Burner"
Old Mar 19, 2012 | 12:15 PM
narlee's Avatar
narlee
They used to have a bolt on water injection kits you could buy. If I remember right it was to run more timing without detonation or for tow vehicles to help them run cooler and not detonate.
Old Mar 19, 2012 | 12:51 PM
OldKarz's Avatar
OldKarz
From: On the bank of the Columbia River..... Washington State
Agreed, now we know!
Old Mar 19, 2012 | 01:08 PM
Ron Miller's Avatar
Ron Miller
Bill
GM put out a service bulletin/directive (whatever) back in the 50's I think for the dealers using water through the carburetor as an accepted method for cleaning the carbon deposits out of cylinders. I've seen copies of the old service bulletin using this procedure.
I've used Sea Foam in much the same way, it did a great job on my Cushman Scooters.
Old Mar 19, 2012 | 01:12 PM
DansYellow66's Avatar
DansYellow66
No. I wonder how they specially prepared the rice? Steamed? Fried?
Old Mar 19, 2012 | 01:18 PM
66jack's Avatar
66jack
Then you can eat afterwords
Old Mar 19, 2012 | 01:46 PM
1955 copper's Avatar
1955 copper
2015 C1 of Year
I've mentioned using water for over 50 years to guys to clean carbon off the top of the piston and valves , even cleans the spark plugs like new , but 99% of the people I tell are afraid to try it thinking I'm crazy .OH well!
I do it once a year on my 55
Old Mar 19, 2012 | 02:18 PM
HHZ06's Avatar
HHZ06
I think the smell out of the tail pipes would make me hungry.
Old Mar 19, 2012 | 02:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
id use a spray bottle with warm water. too easy to hydrolock a motor otherwise. It does work.
Id like to try popcorn kernels just to see what comes outta the pipe..
Anyone take dares?
Old Mar 20, 2012 | 06:26 AM
GeoffM's Avatar
GeoffM
I had a complete car that used that system was called an RX7 never had problems with dirty piston or valves not once!!:
To Strange old technique.........
