Help with chassis paint please...
Old Mar 20, 2012 | 12:05 PM
Kens_62's Avatar
Kens_62
Default Help with chassis paint please...
I'm redoing the frame on my 62. I used Por15 the first go-around but just don't care for how it looks. Now I'm looking for the better alternative. I would like to stick with a satin finish.
Recommendations please?
Thanks!!!
Doug
Old Mar 20, 2012 | 12:13 PM
66jack's Avatar
66jack
Powdercoat...
Old Mar 20, 2012 | 12:14 PM
Dave64's Avatar
Dave64
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
Why not look into powder-coating? It can be done in about any level of shine you desire - cost no more than paint.
Old Mar 20, 2012 | 12:17 PM
John McGraw's Avatar
John McGraw
I always just use a single stage urethane that has been flattened to semi-gloss sheen. I prime with PPG DP90, followed by PPG DCC in Tuxedo black (DCC 9300), and add the specified amount of flattening additive (DX685), to yield a semi-gloss sheen.
This makes a finish that is as tough as nails, and will last for years and years, as well as looking correct. I never took a single point hit for chassis finish at judging with this combo.
Regards, John McGraw
Old Mar 20, 2012 | 12:48 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
tough coat works well.
Old Mar 20, 2012 | 01:07 PM
waynec's Avatar
waynec
I wish! Last time I had parts powder-coated (which admittedly was about 10 years ago) I think I could have had them chrome plated for about the same price. Maybe the prices have come down since then, or maybe my local shop was just way out of line.
I sprayed my frame with slightly-flattened Dupont Imron, which came out nice; would have preferred powder-coat but 'way too expensive.
Old Mar 20, 2012 | 01:28 PM
DansYellow66's Avatar
DansYellow66
I would say John's instructions are by far the best recommendations - especially if your going to drive this car a lot and it gets in bad weather once in a while.
There are cheaper ways to go if necessary. Twenty years ago before I got set up to spray paint I had mine dipped, primered it with spray cans, sprayed it with semi-gloss Rustoleum spray cans and sprayed a coat of low luster clear polyurethane over it out of more spray cans. It looks the same today as it did 20 years ago.
early 90s
today
Make no mistake - there is nothing NCRS correct under there.
If you already have a compressor and spray outfit you have lots of options. If I were doing it today I would use the PPG urethane John mentions.
Old Mar 20, 2012 | 01:51 PM
Kens_62's Avatar
Kens_62
I would and even have a local guy ready to do the job. However, it is sort of the chicken and the egg problem. I have treated the inside of the frame with rust inhibitor and it likely won't stand up to the heat. On the other hand, had I waited until after PC, the inhibitor would have gotten all over the finished product. I felt it more important to make sure the frame doesn't continue to rot from the inside..
Old Mar 20, 2012 | 01:55 PM
Kens_62's Avatar
Kens_62
Thank you. This is exactly type info I was hoping for. Would two quarts do the job?
Old Mar 20, 2012 | 03:01 PM
1snake's Avatar
1snake
It sure must be cheaper in Arizona. My neighbor just had the frame and suspension pieces powder coated on a 23 Ford he's building. The frame is basically a rectangle with 4 cross members. Everything was brand new metal and the cost was $1000.
I much prefer paint. Cheaper and easier to touch up.
Jim
Old Mar 20, 2012 | 04:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Jim
dad had the his 67 coupes frame powder coated. to get the frame and all the other components sand blasted was about 500 bucks then another 500 bucks to have powder coated. turned out great.
Old Mar 20, 2012 | 06:08 PM
John McGraw
Absolutely!
Only flatten the amount you mix to put in the gun. That way, you will have non-flattened material to use for other uses, or you can flatten to other sheen's for other places on the car.
Old Mar 20, 2012 | 06:27 PM
John McGraw
Powder coating prices can vary widely from one vendor to another. I blast my own chassis, and I have a powder coater in San Antonio that has been doing my blasted chassis for $350, and this is for a SRIII frame that is way more work to get coverage on all the round tubes. This same shop does all of Billy Dawson's frames, and is a real big operation A couple of my local shops, regularly get over $1000 to do a frame.
I took a SRIII chassis to a new shop today that is charging me $450, but I don't have to carry the frame all the way down to San Antonio and back. I am sure hoping that they meet my expectations, as I sure am tired of of all the road time, for a competitive price! If I am pleased, I will let everyone know, as Austin has never had a competitive cost powder coat shop until now.
I usually paint original frames, and powder coat resto-mod frames. Sometimes, trying to powder coat original frames that can have oil and grease come out during the bake, can be a real pain. Unless you can have the frame dip degreased, inside and out, I would recommend staying away from powder coat. The problem is, if the grease comes out and ruins the adhesion or looks of the finish, you have to burn all the coating off the frame and start all over. This is why some shops get so much for a chassis, they have gotten burned in the past, and are trying to cover their ***!
Old Mar 21, 2012 | 06:20 AM
aworks's Avatar
aworks
Sem rust shield. It comes in flat, semi or gloss. I use it on all frames. Some of my own cars where done well over ten years ago and still look like day one. Just to make a point, I do drive my cars.
Brian G.
Old Mar 21, 2012 | 09:07 AM
vettjam's Avatar
vettjam
Looking to use SEM Rust Shield on my frame. Can you tell us more about the process and the products you used? I see they have several different numbers including a primer.
Old Jan 11, 2013 | 10:01 AM
Kens_62's Avatar
Kens_62
Just wanted to update this thread and thank everyone for their input. After much thought, I decided to go with John's suggestion. As a matter of fact, I printed it and took it to the local shop. The guy was very happy to oblige.
It was a very hard decision. Basically, I was looking at the same cost (around $500.00) to have it done either by conventional paint or powder coat. The powder coat guy seemed a little more concerned about the rust inhibitor used by Chem-Strip. Either way, the frame came out looking great! I gave the painter a brake backplate I had powder coated Satin Black and he match the tint to a tee.
Thank you again for the help. I start reassembling the chassis this weekend. I still have some powder coating to do but really enjoy that part of the deal. I also have the engine at the machine shop for rebuilding. Hopefully will have a rolling chassis by Spring!
Doug
Old Jan 11, 2013 | 11:01 AM
KCSLED's Avatar
KCSLED
Just did a frame last summer (acid dipped then powder coated) tuff stuff!The inside of the frame turned out great and the powder coating made its way in there to.It was very inexpensive under a grand and a quick turn around very satisfied!!!
Old Jan 12, 2013 | 12:22 AM
John McGraw
Doug
Sounds like you got a good painter! You will not ever regret doing it right. The DCC is real tough, but it is also real easy to touch up.
To Help with chassis paint please...
