flywheel installation
Old Mar 27, 2012 | 09:37 AM
Jaguarmaven's Avatar
Jaguarmaven
Default flywheel installation
Hello,
I'm about the bolt on the flywheel to the crank {crate 350}. The instructions that came with the flywheel {Zoom} said to use threadlocker? I've installed many flywheels and never used any threadlocker before. Any ideas? Also, does anyone remember the torque specs for the flywheels bolts and the pressure plate bolts?
Thanks!!!
Dan Siegel
Old Mar 27, 2012 | 10:27 AM
66jack's Avatar
66jack
Originally Posted by Jaguarmaven
Hello,
Thanks!!!
Dan Siegel
Here are some torque specs for ya.
http://www.stl-vettes.com/65Vette/co...rque_Specs.pdf
Old Mar 27, 2012 | 10:48 AM
Jaguarmaven
Thank you. What about the threadlocker? Necessary?
Dan
Old Mar 27, 2012 | 10:51 AM
1snake's Avatar
1snake
Dan
Necessary? I don't know. Recommended, absolutely. I wouldn't put it together without using blue Loctite.
Jim
Old Mar 27, 2012 | 12:01 PM
Jaguarmaven
Thank you. Will do.
Regards,
Dan
Old Mar 27, 2012 | 12:05 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Dan
Although threadlocker is no substitute for proper fastener torque, it is always a good idea.
Jim
Old Mar 27, 2012 | 12:55 PM
C6Matt's Avatar
C6Matt
and again.. blue... not red..
Old Mar 29, 2012 | 01:29 PM
Jaguarmaven
Thank you. And would you use the blue thread locker on the pressure plate botls as well?
Thx
Dan
Old Mar 29, 2012 | 01:34 PM
jim lockwood
Same situation as in posting #6, as far as I'm concerned.
Jim
Old Mar 30, 2012 | 10:28 AM
Jaguarmaven
Will do. Many thanks.
Dan
To flywheel installation
