63 split
Welcome to the CF. This exact question has been covered many times and can be found by searching. Having said that, check the frame for rust through before the kick up at the rear in front of the tires. Look up under/behind the dash for birdcage rust. If this looks significant, actual metal rusted away, you may want to leave the car alone as this is unbelievably expensive too repair. Do the search and much more is covered. Since the '63 has many "one off" parts, any of them missing can be $$$$
Dennis
Dennis
CF Community Team
2016 C2 of Year
2015 C3 of Year Finalist
As Dennis said, frame and birdcage rust would be my primary concern. Engine #'s, color codes, VIN are areas that need to be inspected that effect price. After sitting so long, I would be concerned about how it runs or whether it leaks.
If you are unfamiliar with mid years, it would be a good idea to find someone in your area who knows these cars to assist you with the inspection. Alot of real Corvette people in your area, both NCRS and others. Good luck
That is true but unless it is totally unsalvageable there are folks that can refurbish stainless to look like new. I do know the glass on each side of the split and the stainless around it, along with the 'cookie sheets' on the hood are hard to find and not cheap.
I'm looking at an SWC right now but the seller is stuck at $63K; it is also a 340HP 4-spd, numbers car with Vintage A/C added...
And make sure it's a 63 split window.Seems the fabled found car in a garage is often a 63 split window when first reported, sometimes isn't even a 60s corvette by the time it's seen uncovered.
