1966 code dates
Old Apr 1, 2012 | 08:57 AM
ddrr713's Avatar
ddrr713
Default 1966 code dates
Can some one tell me where to find the correct date of production on the car's body by Month ,day year etc. Also can you tell by the vin# if it's 194376S111420 Oh and I want to add this ,that in the back of the engine which is out right now the cast says Hi Per Truck ss . Is this still a corvette engine. I'm trying to figure out what is going on from what I've been sold and facts. thanks
Old Apr 1, 2012 | 09:31 AM
1snake's Avatar
1snake
According to the C-2 registry birthday calculator, your car was built January 19, 1966.
Jim
Old Apr 1, 2012 | 09:55 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
What does the pad on the right front of the block read?? Should be two numbers stamped on it. One is a derivative of the car serial number. It should read as follows: 6111420. 6 is model year. First "1" is a place holder. The last 5 are the serial number derivative. That will let you know if the engine is a vette engine or something else.
Old Apr 1, 2012 | 09:56 AM
Mike Ward's Avatar
Mike Ward
To move forward on your engine, please provide the block casting number, casting date and info stamped on the pad in front of the passenger side cylinder head.
Lots of Corvettes have the hi-perf truck notations on the block.
Old Apr 1, 2012 | 10:33 AM
62Jeff's Avatar
62Jeff
For the body, take a look for the TRIM tag mounted under the glove box. Then use forum member Black_Magic's web Trim Tag tool http://www.stl-vettes.com/65Vette/tr...ag_display.htm to decode it. This will tell you when the BODY was built
Black_Magic's birthday calculator http://www.stl-vettes.com/65Vette/bday.htm can be used to tell you approximately when the entire car rolled off the assembly line. Note that the body date and the final birthday of the car may not be the same, particilarly if your body was built at the A.O. Smith plant and shipped to St. Louis.
Old Apr 1, 2012 | 03:40 PM
JohnZ's Avatar
JohnZ
If the "Body" number on your trim tag below the glove box has an "S" prefix, you have a St. Louis body, and the build date code (a letter and one or two numbers) is stamped right below the "let" in Chevrolet at the upper left of the tag. "A" is September '65, and the number(s) is the day of the month.
If the "Body" number on the trim tag has an "A" prefix, it's an A.O. Smith body, and that build date code is when the body was built in Ionia, Michigan, not when the car was final-assembled at St. Louis; you'll need to use one of the calculators noted above with the VIN number to get the production date at St. Louis.
Old Jan 29, 2019 | 07:19 AM
Mccor3843's Avatar
Mccor3843
5th Gear
Default I’m pretty sure that’s your car
Old Jan 29, 2019 | 04:00 PM
65hihp's Avatar
65hihp
Looks like the dog got ahold of that photo.
Old Jan 29, 2019 | 04:16 PM
Mccor3843's Avatar
Mccor3843
5th Gear
that was my fathers old car he owned it for about 30 years I’ve been trying to locate it for about four years now I just found the vin off of an old registration
Old Jan 29, 2019 | 04:26 PM
65hihp's Avatar
65hihp
Then you are hot on the trail now. It's a good looking white 66. Good luck,
Old Jan 29, 2019 | 06:06 PM
Mccor3843's Avatar
Mccor3843
5th Gear
thank you sir my fingers are crossed
To 1966 code dates
