Weekend Projects
Old Apr 6, 2012 | 02:20 PM
Lou64's Avatar
Lou64
Default Weekend Projects
Next week I am off and I want to get the car running like a top. Right now my 64 327/300 runs ok, but sputters when I put the petal to the metal. Everything is stock except for an electronic fuel pump. I am thinking the secondaries on the carb aren't opening, or the fuel pump is not putting out enough pressure. Spark plugs were replaced a year ago.
How do I get the secondaries to open if they aren't? Is it as simple as reattaching some linkage?
Any other ideas?
Also, something is draining my battery (prolly something in my new stereo) so I am going with one of the knife style cut-off switches. That and a polish all the shiny stuff and vacuum of my new carpet and it should be ready to go.
Old Apr 6, 2012 | 02:50 PM
62Jeff's Avatar
62Jeff
300 horse - that's a Carter AFB carb, correct?
First check that fuel comes out of the squirters the instant you operate the accelerator linkage. If you can move the linkage without fuel coming out, adjust the linkage first.
The secondaries open via engine vacuum provided the little lock-out arm is moving freely out of the way first. This little arm is on the driver's side of the carb.
Old Apr 6, 2012 | 03:52 PM
Randy G.'s Avatar
Randy G.
Went to start my '54 a few weeks ago after sitting over winter and the gas went bad. Siphoned all the gas out, put in new gas and once the new gas reached the carbs it ran fine. I think the 10% alky stuff goes bad pretty fast.
Old Apr 6, 2012 | 03:57 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
why the electric fuel pump? what do you have the timing set to?
Old Apr 7, 2012 | 10:16 AM
Lou64's Avatar
Lou64
The fuel comes out fine when the accelerator is operated. The secondaries don't seem to open at all. They should open if you go from idle to full throttle instantly right?
The lock out arm doesn't seem to be doing anything...What does it "lock out." Seems like something here is amiss, but I've never worked on a quadrajet before.
Old Apr 7, 2012 | 10:17 AM
Lou64's Avatar
Lou64
Fuel is not old. Drove the car a couple times this winter.
Old Apr 7, 2012 | 10:18 AM
Lou64's Avatar
Lou64
The electric fuel pump was installed by the previous owner because of vapor lock. Haven't checked the timing, will do that as well.
Old Apr 7, 2012 | 12:24 PM
JohnZ's Avatar
JohnZ
No, the secondaries won't open by revving it in the driveway - the engine has to be under load; the secondaries open based on the engine's demand for air, not just on throttle position.
Are you working on a Rochester Q-Jet, or a Carter AFB? Q-Jets were never used on pre-'68 Corvettes.
Old Apr 7, 2012 | 09:11 PM
Lou64's Avatar
Lou64
Thanks John, I thought that might be the case because the engine runs like a champ when not being driven. How do I tell if the secondaries are opening then?
And I thought the Carter was considered a q-jet, I didn't know Quadrajets were a "brand name."
Old Apr 7, 2012 | 09:57 PM
out2kayak's Avatar
out2kayak
Here is what a Rochester Quadrajet looks like
A Carter AFB:
A Carter WCFB:
A Quadrajet is a very different four barrel carburetor.
For C2 carbs, see:
http://corvette-world.com/corvette_1...arburetors.php
For grins and giggles, a Holley will look something like:
-- Joe
Old Apr 7, 2012 | 10:35 PM
out2kayak's Avatar
out2kayak
Any other ideas?
Based on the above, a few things to check:
1. Fuel line pressure - check with a gauge such as: http://www.amazon.com/Aeromotive-156...3851268&sr=1-2. Cheap and cheerful.
2. If you have proper fuel pressure, check to see that when the linkage drives the carb from full closed to full open you see a healthy stream of fuel sprayed into the venturi (the engine does not need to be running for this check -- just full pressure from the electric fuel pump).
One thing that you don't identify is if the issue is when the vehicle is going from a dead stop or accelerated from cruise. Thoughts?
A bog from idle could be too much play on the throttle plate or the idle speed air screw is set incorrectly (depending on the carb you have).
A bog from cruise can be a bad timing advance mechanism or the secondaries opening too soon. The latter would be (depending on the carb) controlled by weights or a spring. If it's weights, I would seriously doubt that they are out of adjustment, but a spring can weaken with age.
How crusty is your carb? Does it need a good cleaning? When you did a tune up, did you do the points / condenser / cap / rotor / etc? Did you adjust the dwell with a dwell meter (and check to see if everything moved correctly)? After, did you adjust the timing?
Just some ideas...
Old Apr 8, 2012 | 07:55 AM
Lou64's Avatar
Lou64
First of all it is a Carter AFB.
The sputter is from both a standing start or cruise. With the accelerator pushed gradually, the car will travel throughout the rpm range just fine. But if I really slam the gas, it sputters, especially at 3500+.
The carb was totally rebuilt in 2010 by a reputable carb guy who has a vette with the exact same engine.
The timing and dwell were set by my father with timing gun and dwell meter. I will check the timing soon, but don't have the dwell meter.
Old Apr 8, 2012 | 08:07 AM
62corvette's Avatar
62corvette
The 3rd picture is the strangest looking WCFB I've seen. Looks much more like a Rochester 4-jet to me.
A Carter AFB:
A Carter WCFB:
For C2 carbs, see:
-- Joe
Old Apr 8, 2012 | 10:19 AM
out2kayak's Avatar
out2kayak
Updated the pic.
FWIW - Rochester 4GC:
Old Apr 8, 2012 | 11:03 AM
midyearvette's Avatar
midyearvette
if indeed it is an afb, then yes, you should be able to operate the secondaries in the driveway by revving the mill after the choke is warmed up and the lock out is off, the lock out could be the problem or the choke setting.
as far as the miss or poor throttle response, sounds like an ignition problem to me or a vacuum leak at the carb base for starters....jmo....good luck...
Old Apr 8, 2012 | 11:17 AM
62Jeff's Avatar
62Jeff
Default Secondary Lock Out
These photos are of the 3269S Carter AFB on my 62.
The lockout is hiding behind the silver idle/choke plate, here it is blocking the secondaries from being able to open:
And here I'm manually holding the lever out of the way so that if the engine were running the secondaries would be able to open under the proper conditions.
Old Apr 8, 2012 | 04:16 PM
Lou64's Avatar
Lou64
Ok, so what are "the proper conditions?" I get it is run by vacuum from the venturis, but what exactly does it mean if they aren't opening or not opening all the way or opening too soon?
Old Apr 8, 2012 | 05:50 PM
midyearvette
they normally do not open too soon on an afb. the secondary air valve is counterweighted and open with air through the carb. the lock out prevents this until the choke is fully warmed up and open.....look for binding or stuck air valve or sticking lock out or sticking choke......
To Weekend Projects
