67 split window touch sceen nav
Old Apr 6, 2012 | 05:35 PM
paulywannafly's Avatar
paulywannafly
Default 67 split window touch sceen nav
working in limited space I had to use a unit that flips open its lower than the dash pads so it should not block view located a clock power window switches and the last spot is for the header dump switch . I have the white face autometer gauges installed dash goes in next week http://forums.corvetteforum.com/atta...1&d=1333748099
Old Apr 6, 2012 | 07:49 PM
jdk971's Avatar
jdk971
i wish i could think of and do the things you do. you do mighty fine work. jim
