C1 small block ignition shielding???
Old Apr 15, 2012 | 03:51 PM
joseph p's Avatar
joseph p
Default C1 small block ignition shielding???
My friend is looking for shielding for his 1959, does it change in appearance through the years? If so, which years are the same as 1959?
Old Apr 15, 2012 | 06:54 PM
BobT59's Avatar
BobT59
Can't say from personal experience but looking at the ZIP catalog, 56 thru 59 calls for the same shielding part numbers (w/o FI)... 60, 61 and 62 are each different part numebrs w/o FI.
Can't say what the distinction is between them.
Old Apr 15, 2012 | 11:37 PM
Qblue92's Avatar
Qblue92
St. Jude Donor '08
They look mostly the same. I'd get a '61 or so, because the later ones had nice notches in the back that makes installation a LOT easier.
Old Apr 16, 2012 | 06:36 AM
Stewart Allison's Avatar
Stewart Allison
No the shields are different. I can't recall what years but The Skirt on the main shield is shorter and then gets longer. I bought a correct one for my 60 but I had to consult my guru mate to tell me the difference. Stewy
Old Apr 16, 2012 | 03:05 PM
corvette-62's Avatar
corvette-62
IMO...Avoid hassles upfront by buying the shielding specific to your '59.
Old Apr 16, 2012 | 05:43 PM
gbvette62's Avatar
gbvette62
There are 7 different top shielding boxes used between 56 and 62, but all 56-60 carbureted engines use the same one. All of the boxes look similar, with the differences being mainly in the way the bottom edges of the covers are trimmed.
I think that Corvette Central's website, shows all 7 of the boxes.
To C1 small block ignition shielding???
