Keeping Your Engine Clean
Old Apr 25, 2012 | 03:44 PM
DEBrahms's Avatar
DEBrahms
Default Keeping Your Engine Clean
I have no problem blasting dirt off of the engines of my two Hondas in the car wash bay. The modern electronics resist water problems.
However, I'd like to clean off some oil and road dirt from my '58's 270 Duntov, especially around the intake manifold. The old girl does leak a bit here and there. I can't imagine putting the power washer to that engine, though, even with the ignition shielding in place.
How do you guys keep your engines clean? Degrease and then wipe off with rags? Thanks.
Dave
Old Apr 25, 2012 | 03:51 PM
midyearvette's Avatar
midyearvette
i use a pump up bug sprayer filled with kerosene every spring....i just finished this easy chore last week.
once you drench everything, painted surfaces and all, move the stuff around with a paint brush or cleaning brush and then just hose it off with no nozzle on the hose, just gentle water. be sure to cover the alt and carb air horn, then you can dry it off with a leaf blower or use rags....works like a charm and the kerosene gives you plenty of working time......
robert miller's Avatar
robert miller
Dave
Use a cleaning degreaser spray bottle spray on and also wet your rag then get it as dry then spray on the degeaser on the rag and go to town on rubbing the spots that need it...Then with just a clean hot water rag the same thing again..
Old Apr 25, 2012 | 03:52 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I have use Simple Green on the warm engine of my '67. It's very safe for the environment. Let it sit and or work it with a plyable/soft brush. Then spray it all off with lowered water pressure hose. Don't forget to cover the carb and generator. Dennis
Old Apr 25, 2012 | 04:02 PM
DEBrahms's Avatar
DEBrahms
Excellent ideas, guys. Thanks.
I have a concrete driveway with no access to grass or gravel areas. The Simple Green approach may be the best answer for being able to clean my engine and not staining the concrete when I rinse everything down.
Dave.
Old Apr 25, 2012 | 07:31 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
All of the above will work and should be done first....for any stubborn remaining fuel stains, etc.. I've found a cotton ball soaked in brake cleaner is fantastic...wipe it on and let it sit briefly then wipe it off with a damp sponge or rag.
My '61 270HP dual quad engine stays extremely nice and gawkers can't believe I drive it 3-5 times a week and it stays so clean.
I have an extra set of correct, aluminum valve covers that I keep prepped and painted and when the ones on the car get too awful (maybe 14-18 months of driving) I just swap on the spare set in 10 minutes when I'm adjusting the lifters then take the dirty set and prep and paint them for next time.
Old Apr 25, 2012 | 07:47 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
Mineral spirits works well too.
To Keeping Your Engine Clean
