# matching
Old May 2, 2012 | 04:21 PM
maggiesadie8525's Avatar
maggiesadie8525
Default # matching
If you know that the block that is in question is the original motor for the car, but during decking the numbers were erased. If you took pictures before the decking of the numbers and had it notarized by a few people, do you think you could call it the original motor for that car still? Just food for thought.
Old May 2, 2012 | 04:30 PM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Or you could just have the block decked like this.........
Old May 2, 2012 | 04:33 PM
5thvet's Avatar
5thvet
It sounds like it's already done.....
Old May 2, 2012 | 04:36 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
So, to fake one, you would need a crooked lawyer. Now where could you possibly find one of those?
Old May 2, 2012 | 04:39 PM
ifitgoesfast's Avatar
ifitgoesfast
That's a new one (for me). Legally recognize that the engine is original against the natural condition of observation. Legal fiction is a funny thing.
Old May 2, 2012 | 04:42 PM
BarryK's Avatar
BarryK
even knowing the block is original, even having pictures of the block before the decking, and even having "witnesses" to testify it's the original block, the bottom line is that the numbers have been erased and the originality of the block will always be in question to future buyers.
Old May 2, 2012 | 04:47 PM
maggiesadie8525
I would have to agree thanks for all your input
Old May 2, 2012 | 04:48 PM
Mike Ward's Avatar
Mike Ward
You can call it whatever you like. Whether anybody believes you or not is a different question.
I note that you used # (numbers) matching in the title, but then said 'original engine' in the text. Not the same thing to most people.
Old May 2, 2012 | 04:49 PM
maggiesadie8525
What's the difference? Thank you
maggiesadie8525
Default Decking
I'm putting back in the original motor that was.30 thousandths bored already the mechanic said he thinks up to .60 thousandths will do. But if doesn't a sleve would have to be put in. If i select to go that route i'm just looking ahead i will find out this friday i hope where we sand with it. There shouldn't be any problems. I just like to know my options if any.
Old May 2, 2012 | 04:52 PM
BarryK's Avatar
BarryK
it's SUPPOSED TO BE the same thing, but unfortunately over the years and with the dishonestly of so many sellers it really isn't anymore
Old May 2, 2012 | 04:57 PM
ifitgoesfast
Why did you notarize the photographing of the engine stamp pad before it was decked?
Old May 2, 2012 | 05:02 PM
maggiesadie8525
For the scrape book my son is putting together
Mike Ward's Avatar
Mike Ward
Original engine means only one thing- the original engine that GM installed in the car on the assembly line. In your car you know that's what you've got but have lost the all important evidence that could prove it.
'Numbers matching' used to mean the same thing but now means anything from the basic casting number is the same as the original but blown up engine that I now use as an anchor to all the original ID numbers have been altered to match what I wish they were.
In your case, you've got no numbers on the pad 'to match' anything else. It might be original, but it's not 'numbers matching'.
Old May 2, 2012 | 05:12 PM
maggiesadie8525
The numbers are still there the block was never deck. I just threw out a question "what if" i have no dought that this block will bore less than .60th thousandths.
Old May 2, 2012 | 05:20 PM
vettebuyer6369's Avatar
vettebuyer6369
You could "call" it anything you like. Some people may or may not choose to believe it.
It is no longer "numbers matching" though, no matter what you call it.
I told my rebuilder I'd nuke his shop if the numbers on my '69 were breathed near during decking.
Old May 2, 2012 | 05:28 PM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
Geez, you are back less than a day and you are slamming some of us already ................................. ......................
To # matching
Old May 2, 2012 | 06:00 PM
Mr D.'s Avatar
Mr D.
I will just say good luck with that.
Old May 2, 2012 | 06:33 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Deck it like the above post. Then the issue is moot.
Old May 2, 2012 | 06:45 PM
NOM61's Avatar
NOM61
In the spirit of the post, I'm wondering if the same techniques used to recover "removed" serial numbers on guns could be used to verify a decked pad stamp? Does the stamping "impression" penetrate as deep or deeper than a firearm serial number?
DT
