Antenna Cable
Old May 9, 2012 | 03:34 PM
TX63CONV's Avatar
TX63CONV
Default Antenna Cable
Got my radio back from Gary Tayman and went to remove the antenna cable at my old radio last night. Pulled on what I thought was the plug but must have been the actual cable as the plug separated from the cable.
Can I just cut the cable a little shorter and re-crimp the plug back on? The copper wires seemed to have unwound and not familiar with this I gave up and went to bed.
Is it similar to COAX and do I need a special tool?
Old May 9, 2012 | 05:59 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
There are antenna cable repair ends. Radio Shack used to sell them. If you can't find one let me know. I think I have one in the garage.
Old May 9, 2012 | 09:37 PM
vt65's Avatar
vt65
any Cable TV installer should be able to repair it for you...take about 2 mins ...
Old May 12, 2012 | 01:55 PM
TX63CONV's Avatar
TX63CONV
Of course Radio Shack doesnt have them in stock. Going to check out a local car radio shop today. The problem is I was able to cut enough wire off that I see the inner copper wire and I think I can get to it. However, what came out of the piece that broke is this:
What is that transistor looking thing on the end?
I REALLY do NOT want to replace the cable.
Old May 12, 2012 | 03:46 PM
JohnZ's Avatar
JohnZ
That's an in-line capacitor - all OEM antenna cables had them; it fools the radio into thinking that the antenna mast is the correct length for optimum reception of AM signals, and has no effect on FM reception.
Old May 12, 2012 | 06:44 PM
TX63CONV's Avatar
TX63CONV
So if I understand this correctly, I could find a plug similar to this one:
http://cartoys.com/products/product....__5_Pieces_Bag
And use my existing cable? What I dont understand is where the inner copper wire goes inside the male plug? Do I just leave it long enough so that it comes into contact with the metal tip?
Old May 12, 2012 | 08:35 PM
Silverblue64's Avatar
Silverblue64
Active Streak: 90 Days
Does anyone know if the repro antenna cables on the market today contain this capacitor? I do like listening to the AM band from time to time.
Old May 12, 2012 | 08:49 PM
Sky65's Avatar
Sky65
The center wire attached to the center pin of the end. The shielding attaches to the outer sleave. Pm me your address and I'll send you the one I have.
To Antenna Cable
