Dynamic Compression Ratio
Old May 10, 2012 | 10:17 PM
Bud2's Avatar
Bud2
Bud2
I just went onto Cometic's site. Maybe I'm just plain stupid but I couldn't find a gasket there that was over .040. Put in the stock number and it came back with nothing.....
I dunno, I'm gonna have a cup of tea and a laydown.
Bud.
Old May 10, 2012 | 10:35 PM
65tripleblack's Avatar
65tripleblack
Originally Posted by Bud2
My flat topped pistons have 5cc in the valve reliefs and are 0.012 down in the hole. The piston ring height is .2236, 0.003 piston to bore clearance. 65cc AFR heads. 6 inch Scatt rods. The Felpro 1003 gasket is 0.041 after torqued. The HR cam is Lunati lobe separation of 106, advertised duration of 290, IV closes at 41.5 (@.050 lift). What have I left out??? Anyway, I've had results of DCR of 8.83, 10.34, 8.92, 8.46.
I thought this was maths. If I'm using the same figures why am I getting different answers?
So, am I in the poo?
Bud.
Oh, forgot to say the bore is 4.030 and the stroke is 3.75. It's a 383.
Your SCR (static compression ratio) is 10.598:1.
You must use "advertised" duration for valve events when calculating dynamic compression ratio (DCR). Based on the info you provide, it looks like your cam is the Lunati 60112. You can not use 0.050" valve timing events, and so, 41.5 degrees is way out of line. Lunati uses actual durations at .006" valve lift (SAE J604D) to figure advertised durations. Using this information, along with the recommended installation timing (4 degrees advanced with a 110 LCA, 106 ICL and 114 ECL) and 282 degrees advertised intake duration, the intake closing event is as follows:
IVC = ICL + [intake duration/2] - 180 = 106 + 141 - 180 = 67 ABDC
Using this, along with a 3.75" stroke and a 6" con rod yields a 2.86" dynamic stroke and a 8.32:1 DCR, which is excellent.
Congratulations on a well thought out build!
Now go to sleep and don't change anything.
Old May 10, 2012 | 10:49 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Just a question on that thicker head gasket, would that have any influence on the relationship with the intake?
Bud.
No.....
.010 will not make difference unless it is way off to begin with.
I still think the compression is a little high....but the DCR numbers support
it.
I never built them that high for two reasons:
1)You will never miss the power.
2)You can run garbage if you can't find the good stuff in a pinch.
Your call......will run fine either way.
Jebby
Old May 10, 2012 | 11:09 PM
Bud2's Avatar
Bud2
Bud2
The tea was soothing. Found the gasket at Summit.
Bud.
Old May 10, 2012 | 11:13 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Bud.
Great!
Another added benefit of MLS head gaskets is they handle 250+ shot
of nitrous without a hiccup.
Jebby
Old May 10, 2012 | 11:23 PM
Bud2's Avatar
Bud2
Bud2
[QUOTE=65tripleblack;1580781466]Your SCR (static compression ratio) is 10.598:1.
Well... My cam card indicates its the #50199 and they note the timing figures are at .050". Lobe center line of 102. Now that's not exactly what you said - so am I still in the poo without the .051 gasket?
Bud.
Old May 10, 2012 | 11:32 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
[QUOTE=Bud2;1580781876]
Bud.
50199 is a generic custom grind code......most likely someone was smart and
had this ground on a .990 base circle.
This is necessary with a 3.750 stroke crank....so it will not contact the rod bolts.
I crossed your duration specs as it jibes with what Tripleblack says.....
The DCR is measured like TB said with advertised duration @ .006
You should be fine.
So yes...go to sleep
Sorry to get you stirred up earlier......
Jebby
Old May 10, 2012 | 11:49 PM
Bud2's Avatar
Bud2
Bud2
Good night all! And thanks for the help. (I'll probably have nightmares about cams!)
Bud.
