1962 corvette disc brake conversion problem
Old May 10, 2012 | 09:04 PM
plab069's Avatar
plab069
2nd Gear
Default 1962 corvette disc brake conversion problem
hello to all, I have purchased a disc brake conversion kit from ecklers, I have followed every single step everything is installed but for some reason I cannot bleed the lines. Can anyone help me out?
Old May 10, 2012 | 09:14 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
did you inadvertently drain the master cylinder? if so, it needs to be bled first.
the only possible reason mechanically i can think of is if the calipers are somehow installed with the bleeder screw at the bottom rather than the top of the caliper..., otherwise they should bleed like any other wheel cylinder
how are you bleeding it? someone helping you? pressure bleeder? vacuum bleeder?
Bill
Old May 17, 2012 | 07:08 PM
plab069's Avatar
plab069
2nd Gear
I have primed the master cylinder. I am bleeding by pressure and not vacuum has they are not power disc brakes. The rear brakes are working fine but i cannot seem to get the front to bleed.
Thanks,
Pat
Old May 17, 2012 | 08:28 PM
63split63's Avatar
63split63
Try letting them gravity bleed. Do them 1 at a time, leave the bleeder open and have a couple of beers . It could take a while but worth a try.
Bill
Old May 17, 2012 | 09:50 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Thanks,
Pat
whether they are manual or power brakes has nothing to do with how you bleed brakes. you pump up, hold, open bleeder, hold pedal down when pedal gets to the bottom, close bleeder, let pedal up; repeat as necessary to get a firm high pedal (check fluid level in mc as you go)... if you do that, then it's got to work...
Bill
Old May 17, 2012 | 10:12 PM
GCD1962's Avatar
GCD1962
As Bill noted, the position of the bleeder is critical. On some applications it bolts at an odd angle which hinders bleeding correctly. This should be noted in the instructions.
Old May 17, 2012 | 10:35 PM
street62's Avatar
street62
I had the same problem. tryed everything . Got rid of the combination valve and use a adjustable valve for the rears , the combination valve was shifting when bleeding. And also use risidual check valves in the lines , 2lb's for the front disk brakes and 10lb's for the rear drum brakes. now I can get a hard pedal.
Old May 17, 2012 | 10:40 PM
Plasticman's Avatar
Plasticman
Let's ask some basic questions:
Is this a dual master cylinder conversion, or are you using the original single M/C?
I assume you are getting fliud out the bleeders, but not getting a hard pedal?
Note: If you are using the original M/C, you will need to remove the residual pressure valve located at the front of the M/C (requires disassembly of the M/C), to prevent the disc brakes from dragging. I have no residual pressure valves (front discs / rear drums using the original M/C), and know of several other C1 Vettes with essentially the same system, and they have never had an issue.
Plasticman
Old May 25, 2012 | 10:32 AM
XLR8OR's Avatar
XLR8OR
Always bench bleed the calipers before you install them. Using the master cylinder to bench bleed is tough because you are trying to force an air bubble to travel against gravity (air rises). If you have the means, get a pressure bleeder - you'll be done in 10 minutes and never have a soggy pedal again.
To 1962 corvette disc brake conversion problem
