Wcfb question
Old May 12, 2012 | 02:33 PM
corvette-62's Avatar
corvette-62
Default Wcfb question
I have replaced the Rochester 4-Jet carb on my '62 327/250HP with a correct date coded original WCFB. I've tuned and retuned this carb many times, to the point where I can pump the accelerator once, have the engine start and idle effortlessly. In nuetral I can rev the engine to red line with no bog or hesitation. However under load, the engine bogs down and I get minimal acceleration when the pedal is floored. In normal driving situations the engine performs well. I thought the Carter would give me the same or better performance that I got from the Rochester. My question is what am I doing wrong or is it the carb itself?
Old May 12, 2012 | 02:37 PM
MikeM's Avatar
MikeM
Are your metering rods adjusted correctly and the right parts?
Old May 12, 2012 | 02:40 PM
corvette-62
I'm taking a guess here Mike and saying, "yes" only because the WCFB had a total rebuild prior to installation on the engine.
Old May 12, 2012 | 03:05 PM
MikeM's Avatar
MikeM
I'd get a manual and check the metering rods. Also check the float levels.
Is your throttle rod pulling the butterflies all the way open?
That carb should run about the same as the Rochester.
Old May 12, 2012 | 03:34 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You need to check the condition of the step up springs.....if worn
they will not allow the rods to raise fast enough to flow fuel.
Also look for a strong pump squirt.
Jebby
Old May 12, 2012 | 03:41 PM
corvette-62
Just checked the WCFB...I have a strong pump squirt & the butterflies open all the way...As I stated...at idle with no load this engine will scream just like when I had the Rochester on, but under load I can only get it up to aprox 4500 RPM then when I shift it's fine until I get up to aprox 4500 RPM again...could the trouble be the timing instead of the WCFB??
Old May 12, 2012 | 03:44 PM
MikeM's Avatar
MikeM
Could be timing, could be the points are dirty are not gapped right, could be plugs dirty, could be.......................
What did it run like before you changed over and what all did you disturb?
Old May 12, 2012 | 03:48 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
It is running out of fuel.....like I stated....check the step up springs....they should be nice and strong....if the metering rods are stuck in the jet= not enough fuel....
Float level and fuel flow to carb are also considerations....if the float is way too low....the bowl will only fill so far.
Jebby
Old May 12, 2012 | 04:02 PM
corvette-62
It ran like a "neck snappin'" 300 Horse!! I didn't disturb the plugs..just readjusted the timing, and swapped in a new air filter. I think Jebbysan might be on to something ..maybe it's starving for fuel under load..Just "crusin'" it's fine..but I want that "Kick in the Pants" back...so install new springs??
Old May 12, 2012 | 04:05 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
check all the things he said; springs will be the easiest to do first, but the other checks are worthwhile.
Bill
Old May 12, 2012 | 04:07 PM
MikeM's Avatar
MikeM
We are both telling you the same thing! Starving for fuel.
Metering rods mis-adjusted or the spring not pushing the rods out of the jets will do the same thing.
Never seen weak springs but there's a lot I haven't seen.
Old May 12, 2012 | 04:11 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yeah weak spring may be hit or miss....but also check for proper plunge up and down....make sure it is moving freely....
This is a kick *** site.....lots of good info here:
http://www.capital.net/com/studiog/CarterWCFB/
Jebby
Old May 12, 2012 | 04:15 PM
corvette-62
O.K. Let's start with the easy stuff..the springs...are they easy to find for an old carb like this? Any of the "Corvette parts suppliers" carry these, do you think NAPA has them? Or is it more of a "specialty carb" thing?? Also thanks guys for all the helpful info..much appreciated!!
Old May 12, 2012 | 04:19 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
More of a "specialty carb thing"
Just check for good spring back and freeness.....if the rods snap up good and quick....move on.....
Read the link I showed you....great info with pics!
Jebby
Old May 12, 2012 | 11:40 PM
Pilot Dan's Avatar
Pilot Dan
Air horn needs to come off and re-check your float level (which I am thinking is set TOO LOW). Here is a picture of the correct Kent Moore original tool from my collection which works like a charm. Re adjust the floats and I think your problem will be soved.
Pilot Dan
Old May 13, 2012 | 06:14 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
ABSOLUTELY check the timing as MikeM suggested before tearing into one of these carbs...a loose distributor hold down bolt could be all that is wrong. THEN check the float level and the vacuumeter plunger (the leather or rubber disc that gives these old carbs their pump shot)....you may appear to have a nice stream when the car is sitting but its not enough under load. This part can deteriorate over time.
And only AFTER THAT screw with springs, metering rods, etc.. The springs in this carb are hardly under much stress and I've never had one give me a problem unless its the WRONG spring. Low vacuum, 'cam' cars like Duntov 270HP have less aggressive springs to make things work easier.
Here are the troubleshooting pages from the old Packard WCFB manual; its the same carburetor basically. I doubt Packard Inc. is worried about these being posted electronically at this point. www.daytonaparts.com has very nice rebuild kits that are setup for modern fuel... You will never find those old float gauges that Pilot Dan has so you just have to eyeball it some other way as I do.
Old May 13, 2012 | 08:31 AM
knockbill's Avatar
knockbill
Here are the troubleshooting pages from the old Packard WCFB manual; its the same carburetor basically. I doubt Packard Inc. is worried about these being posted electronically at this point. has very nice rebuild kits that are setup for modern fuel... You will never find those old float gauges that Pilot Dan has so you just have to eyeball it some other way as I do.
i agree with the starving for fuel assessment,,, i don't think teh pump is the problem, as it seems to lose power at 4500rpm,,,, i've found the trickiest adjustment to make, is teh floats, side to side measurement, or more simply, centering them in teh bowls,,,if they touch teh sides of the bowls, as it fills, the bowls won't fully fill ...
use the manual just posted, and go thru the carb again,,, teh procedures are in there, just check that the measurements are right for your carb...
To Wcfb question
Old May 13, 2012 | 09:36 AM
corvette-62
The 2 things that are a PIA (read "clueless") for me on my '62 are electrical and carburators. It now seems that before I take this WCFB off the manifold I should focus more on the floats that need adjusted. I get the impression I'm running too lean. In reading the replys I'm getting the sense that I need some sort of meetering tool for adjustment(?). Am I able to adjust the float without taking the carb off the manifold? Anybody have the time/patience to walk me through this?.... Hey Frankie wanna come back to Pittsburgh??
Old May 13, 2012 | 09:47 AM
hedgehead's Avatar
hedgehead
From: I'm not doing as well as I expected, but I never expected I would
Might just be the fuel filter.
Old May 13, 2012 | 12:46 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You can adjust the floats with out removing the carb.....
Undo the fuel line......remove all of the air horn screws.....crack the
airhorn lid from the base.....lift gently...at this point rotate the lid until
you can wiggle out the accelerator pump rod......
From there follow the float drop instructions from the website I posted.
I am ruling out timing because it was ok before you swapped carbs....
It would have to be grossly retarded to make the engine not rev.
Jebby
