Original cam
Old May 21, 2012 | 06:27 PM
maggiesadie8525's Avatar
maggiesadie8525
Default Original cam
What would be the correct stock cam for a 66 corvette l79?
Old May 21, 2012 | 06:40 PM
Westlotorn's Avatar
Westlotorn
Sealed Power CS179R and there may be other options from Comp Cams or Crane Cams.
Old May 21, 2012 | 07:03 PM
knockbill's Avatar
knockbill
i have a 68 l79, and used a nos gm151 cam,,,, not sure if its the same in 66...
Old May 21, 2012 | 07:07 PM
toddalin's Avatar
toddalin
Crane Cam Part #967601 is their replacement.
That's what I use and it can make some power.
Old May 21, 2012 | 07:23 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
I would go with the Speed Pro original grind.
I think this is the 327/350 HP
SEALED POWER Part # CS1106 FOR THE "151" CAM
http://www.rockauto.com/catalog/x,ca...,parttype,5260
Many cam makers "improve" the factory specs and call it a replacement.
Old May 21, 2012 | 07:52 PM
MikeM's Avatar
MikeM
Stick with the stock replacement and you won't have to get all worked up about $10/quart oil to keep the cam eccentric.
Old May 21, 2012 | 09:46 PM
65tripleblack's Avatar
65tripleblack
Nope.
That's the 12353918 "GM Crane Marine and Off Road" cam. 214/224 112 .442/.465
CS179R is the one he needs. 222/222 114 .447/.447
Old May 21, 2012 | 10:40 PM
toddalin's Avatar
toddalin
Originally Posted by 65tripleblack
Nope.
Same specs as the Crane cam.
http://www.summitracing.com/parts/CRN-967601
Old May 21, 2012 | 11:09 PM
MiguelsC2's Avatar
MiguelsC2
Nope.
Thats correct. I wasn't sure about that part number I listed.
Cranes cam may be original specs. Most of the others aren't. Certainly not comp cams version.
Old May 22, 2012 | 01:14 AM
Westlotorn's Avatar
Westlotorn
I believe Camshaft Machine is the maker behind Sealed Power cams, I am sure they sell to other vendors but they don't sell direct to the public.
To Original cam
