C2 Dash Cluster
Old May 25, 2012 | 02:20 PM
dcaggiani's Avatar
dcaggiani
Default C2 Dash Cluster
Has anyone machined their own C2 Dash Cluster in order to use non-original Gauges?
Classic Instruments will custom fit their gauges into the original dash cluster and Dakota Digital has the digital version (analog look coming in 1 year) that fits the original cluster.
I have seen others modify the cluster to fit VDO, Autometer and so on...
Comments?
I have added the options I have found on the web site:
www.vetterodder.com
Old May 28, 2012 | 04:48 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Comments?
www.vetterodder.com
I am working on this right now... I put up a post some time ago but there did not seem to be much interest.
Looks like I am going to have a stock cluster white light scanned, remove the stock bezels from it. Recreate the holes that will accept the Autometer or other aftermarket gages. Not sure if I am going to complete a model so finished parts could be machined, use some sort of a rapid prototype process, etc.
If there were interest in making 10 of them or something, I might put a little more effort into it.
The goal would be to make something that looked similar to stock, bolted in the stock location, used some of the stock switches, but had the capability to use any of the aftermarket gages.
I have a complete set of gages already for my resto mod including a boost and oil temp gage, the balance of the gages replicate the stock instrumentation, with the exception of the volt meter.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old May 30, 2012 | 11:57 AM
Ron Champe's Avatar
Ron Champe
[QUOTE=dcaggiani;1580906690]Has anyone machined their own C2 Dash Cluster in order to use non-original Gauges?
I installed Auto Meter Ultra Lite gauges in my stock cluster...no machine work was necessary. The tach and speedo is 5" in size and all other gauges are 2 1/16".
1. I layed the bare cluster face down and placed, aligned and leveled each gauge "resting" on each cluster gauge opening.
2. I then placed the stock cluster inner ring bracket in place and siliconed the bracket to the cluster. The Auto Meter gauges have a flange which the ring rests on. Once dry, I also installed the gauge brackets furnish by Auto Meter.
3. Since the Auto Meter gauges are deeper in size than the original gauges, the rear cluster cover can't be used.
6. Lastly, I wired all new cluster gauges into a plug-in so in the event of a problem I just unplug the complete cluster and out it comes.
Hope this helped.
Old May 30, 2012 | 04:48 PM
Islander21's Avatar
Islander21
After months of looking at gauge cluster restoration options I decided to order Autometer custom gauges (they keep the look and feel of the orignals) and use my 66's cluster without modifications. Note that I'm using an LS2 engine on my resto-rod.
I too considered bonding, gluing and/or expoxying the gauges to the cluster and ruled that out, but Joe Lutz at Hot Rod Dynamics has come up with a clever kit that allows me to install Autmeter gauges without mods so I'm using that. It should work for any Autometer gauge set with 5" tach/ speedos and 2 1/16" small gauges.
I am now waiting for my custom gauges and don't expect them until late June at the earliest. In the meantime I will be stripping the cluster and reparing some damage I found after taking it out of the box it came in when I bought the car. I will be posting a link to my step-by-step install of the kit and also posting a video.
Old May 30, 2012 | 05:40 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Old May 30, 2012 | 06:03 PM
BlackMoon's Avatar
BlackMoon
[QUOTE=Ron Champe;1580943598]
Hope this helped.
I don't remember any glueing or epoxying of gauges. I just used the brackets that came with the gauges. Mine looks identical but is black in color. Gauges are 2-5/8". Good looks and reliability. I spent over $800 having my gauges redone by a well known restorer and two failed within the first 5 hours of use.
Old May 30, 2012 | 06:30 PM
Islander21's Avatar
Islander21
[QUOTE=BlackMoon;1580946576]
Originally Posted by Ron Champe
Mine looks identical but is black in color. Good looks and reliability. I spent over $800 having my gauges redone by a well known restorer and two failed within the first 5 hours of use.
That cluster does look really nice, and your gauge restoration nightmare is one reason I chose aftermarket gauges.
Old May 30, 2012 | 06:45 PM
BlackMoon's Avatar
BlackMoon
Here's mine in black.
Old May 30, 2012 | 06:55 PM
BlackMoon's Avatar
BlackMoon
[QUOTE=Islander21;1580946756]
I think I spent about $550 for all the gauges after $800 for restored originals. In the end I'm extremely happy with the choice and since restored clusters are worth about $2,000 I'll be even happier after I sell it.
I wouldn't go with the 2-1/16 gauge. The larger 2-5/8" fit fine and are easier on the eyes.
Old May 30, 2012 | 08:05 PM
joeelutz's Avatar
joeelutz
These are the Autometer American Muscle series gauges we just installed in a 65 Corvette along with an LS3 and Tremec 5 speed. I chose this series because it matches very well with the stock glovebox.
Old May 30, 2012 | 08:09 PM
BlackMoon's Avatar
BlackMoon
Those look great. I don't think that series was available when I did mine or I might have gone that direction. Very nice.
Old May 30, 2012 | 08:10 PM
joeelutz's Avatar
joeelutz
Thanks! I think this series just came out.
Old May 30, 2012 | 08:15 PM
BlackMoon's Avatar
BlackMoon
Is that a tilt steering column you have? Was that available in 65?
Islander21's Avatar
Islander21
Here are the custom Autometer gauges I ordered. They had no green paint to match the original so I went with silver to match my interior and blue LED gauge lighting to match the Laguna Blue exterior.
Old May 30, 2012 | 08:17 PM
joeelutz's Avatar
joeelutz
It's a Flaming River unit.
Islander, those gauges are very nice and clean. OEM like.
Old May 30, 2012 | 08:19 PM
Islander21's Avatar
Islander21
Thanks, that was the goal.
I went with Ididit tilt column and chose the black powder coated version. No tilt column option was available on C2s, BlackMoon.
Old May 30, 2012 | 08:21 PM
BlackMoon's Avatar
BlackMoon
Thanks Joe.
Islander- Why are they custom, color?
To C2 Dash Cluster
Old May 30, 2012 | 08:32 PM
Islander21's Avatar
Islander21
Thanks Joe.
Like Joe pointed out, I wanted them to have the look and feel of OEM gauges. There is nothing like that in the Autometer gauges they sell off the shelf. Some came close but they either did not have 5" tach/speedos or were not full electronic kits.
So I looked at their custom shop section and created my own from their available silk screen patterns, colors, fonts and pointer options. You can even change the bezel style and color as well as the glass shape. I paid a bit more than I would have for a stock set but it was worth it for me. Here's a pic of OEM gauges (thanks to JohnZ) for comparison's sake:
Old May 30, 2012 | 08:42 PM
BlackMoon's Avatar
BlackMoon
Wow those look great and match the OEM. You are going to LOVE having gauges that work (all the time).
Old May 31, 2012 | 06:28 PM
dcaggiani's Avatar
dcaggiani
Awesome stuff!
I will add the Hot Rod Dynamics option to the list - thanks.
Dan
www.vetterodder.com
