gel coat
they got a brown primer then paint
1. Gelcoat is polyester based, as is Slicksand, Featherfill, and a host of other high build surfacers.
2. Polyester and vinyl ester products shrink up to 7% volumetrically and
because it continues to cure over long periods of time this
effect may not be immediately obvious. This is what causes the "print through" or "dieback" effect on repaired areas. Epoxy shrinks 2% TOTAL (approx 90% during the first 5 days).
3.As a general rule epoxys are twice as expensive as vinyl esters
and vinyl esters are twice as expensive as polyesters.(I think that Corvette Image uses vinyl esters in the manufacture of their parts).
4.Epoxys have performance advantages over polyester and vinyl
esters in five major areas:
- Better adhesive properties (the ability to bond to the
reinforcement or core)
-Superior mechanical properties (particularly strength and
stiffness)
- Improved resistance to fatigue and micro cracking
- Reduced degradation from water ingress (diminution of
properties due to water penetration)
-Increased resistance to osmosis (surface degradation due to
water permeability)
5.Epoxys have far better adhesive properties than polyester and
vinyl esters. The superior adhesion of epoxy is due to two main reasons. The first is at the molecular level, where
the presence of polar hydroxyl and ether groups improves adhesion.
The second is at the physical level - as epoxies cure with low
shrinkage, the various surface contacts set up between the liquids and the reinforcement are not disturbed during cure. The result
is a more homogenous bond between fibers and resin and a better
transfer of load between the different components of the matrix.
6.After a cure period of seven days the tensile strength of the epoxy is 20 to 30% higher than those of
polyester and vinyl ester.
I could go on, and take no credit for the above information. It was part of a study done by a major resin manufacturer. While ALL repairs cannot be done with epoxy, my thought is that the ones that can.....should. I use a high quality body filler (low shrink). I use only ISOPHTHALIC poly resins (mold maker resin, low shrink). I use epoxy primer/sealer/surfacers under the paint.
If you have a car with little or no bodywork, then I suppose that one of the polyester surfacers will be ok. I used them for years. If you're doing a dark colored car, and have significant bodywork, I would use the epoxy vs. gelcoat or polyester surfacers. BTW, the volumetric shrink on polyester (not isophthalic), is about 5 percent over the first 5 years, and 2 percent over the next 2 years, which is why you see sanding scratches, bodywork, etc., coming through a paint job several years after it was painted.
These are my opinions and observations. I've painted hundreds of cars. Problems don't show up on every car, and as I've said, I used polyester products for years.....some with problems, and some without. I posted this for information only, and is certainly not intended to be for everybody.
Mike Coletta
I understand your use of high-quality fillers, but do you use a sort of "high build" epoxy for blocking one out? The epoxy I've used (the old ppg DP90 comes to mind) is paper thin when cured and shows everything, and is "non sanding."
Mike Coletta
Mike Coletta
i read ppg's instuctions, and have a couple questions,,, how long can the car stay in this primer before the top coat is necessary, or doesn't it matter? what do you use to clean the paint gun? will laquer thinner work, or does ppg have a special cleaner.,,,
thanks again for your help....
http://www.bapspaint.com/docs/psheet...obal/EU091.pdf
Lacquer thinner for cleanup.....but before it dries. NOTHING will cut it after it flashes....except sandpaper.
Mike Coletta
Mike Coletta
excellent info,,, i appreciate your willingness to share your experience, and your time with us....
) amount of resin on the preform, close heated mold, remove surround 5 minutes later, trim, and ship. "gel-coat"
Is it, or not?
There was no gel-coat on any Corvette panels after 1954 (except for low-volume hand-laid parts like the wheelhouse inner panel caps on big-tank midyears).
