I think that mounting it in the dash is the issue. Seems to me that the passenger car/truck switches were the same, but the body of the switch is too short to mount to the dash.
Mike Coletta
Mike Coletta
hey mike ,,
thanks for teh reply,,, mounting isn't teh problem, i just had to file a notch to clock it so teh vacuum tubes would clear, and have the cable facing the right direction,,, i'm wondering if it will operate teh switch on teh motor,,, i guess they're mechanically the same... do you know if the cables are the same length....
