alternator plug wiring
Old Jun 12, 2012 | 08:43 AM
CP64365's Avatar
CP64365
Default alternator plug wiring
I noticed that my battery was not charging in my 64 coupe . I found the problem was a broke wire on the two-wire plug connector. So I striped the insulation off of the wire and inserted back into the metal connector tab of the plug. I tried using some needle nose pliers to crimp the wire to the metal connector. I'm not sure if it will hold. Is there a way to remove the metal connector from the plastic plug to crimp the wire more securely? If not I may need to buy a new plug connector.
Dave
Old Jun 12, 2012 | 08:57 AM
MikeM's Avatar
MikeM
Slide a very small flat blade up in the back side of the hardshell and you can release the lock that holds the metal terminal in the hardshell. Buy a new terminal, crimp it and shove it back in the hardshell.
Old Jun 12, 2012 | 10:50 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
alternator plug pigtails are available at any FLAPS; just get a new one.
Bill
To alternator plug wiring
