Just received my new shielding from zip, does anyone have an instalation guide or know where i can get directions on how to install, can i install all the shielding while the engine is out of the car.
bruno vetter63@comcast.net
this is my email if anyone has directions please send to this address.
You will need to raise the motor a bit and loosen the engine mounts for the lower shields.
This diagram is your best bet. You just need to get the parts out and puzzle them together. You will find the pieces fall into place.
you will need to raise the motor a bit and loosen the engine mounts for the lower shields.
miguel
thanks for the help,i have the engine out and all painted and ready to put back in. Can i put all the shielding on before replacing the engine?
bruno
Vetter64
I put on the "V" shields, plug heat shields, plugs, and routed the plug wires up over the back of the engine with it out of the car. You should not put the other shielding on until the engine is in the car, or the distributor for that matter. It will hit the firewall when installing.
CUL Jim
Reason: update URL for pix.
Vetter64
CUL Jim
