$28,000 - $50,000 depending on condition, engine option, accident history, and whether or not the car has the all of the original, stamped, date-code-correct parts of the drivetrain.
Everything is original no accidents, Its clean but not perfect Bias ply Tires are weather checked, 300hp still has the original Air Cleaner Cable drive Tach
When talking soft top cars, is there much of a difference in value from 1964 to 1965? I am talking engine and trans aside just based on the year?
My opinion, both are way overpriced. They are just old cars. YOU as the BUYER are the one that sets the value threshold.
Now, if you really do have a car that has only 45K miles from new on it, I wouldn't care what year it was, that's worth a big premium to me, regardless of the year or options.
People like to hold up disc brakes on the '65 and a different interior design as reasons the '65 is valued higher. Maybe, but isn't worth anymore to me. A good solid car is worth more and I don't care if the engine is original either.
I guess it depends a whole lot on how long you've been playing around with old cars and what's important to you.
There is good reason to drink upstream from the herd!
Mike is dead on. A good solid car trumps any particular year. The '65 phenom is overplayed. For street driving, I will take the drum brakes all day long over the disc. Cheaper to maintain, too.
Another rationale for the '65 is the 396 option. Unfortunately, those who point to that strength always own a SB.
Thanks for the reply. I kind of though that about the '64. I actually like the interior and the fender grilles better than the '65. Every time i find a good '65 it has something wrong or missing or NOM. The '64's seem to be a little more original.
I actually like the interior and the fender grilles better than the '65..
If that's the year model that appeals to you most and you find a good example, great, you're in luck.
They're the most affordable of all mid years, so post some pics when you get it.
Good luck
So is the main difference in value the disc brakes?
Read post #10 again.
Don't know about the difference in value. The MAIN differences are the disc brakes, the interior, the grille and the lower, rear front fender lines. If those features are worth more to you, go for it!
Be advised though that some '65's had drum brakes if that means anything to you. Also be advised that many/most midyear odometers usually broke between 25-50K miles. If the car(s) you're looking at has a working odometer, you won't have any idea if it's ever been non-working unless you give the car a good look and drive.
I have a '63 convertible and a '65 coupe. The '65 coupe has about 45K on it from new. It's tight, doesn't squeak/rattle, the OEM suspension is tight. Basically, it drives like a new car and because of the low miles, doesn't need all the running gear rebuilt, overhauled, up on jack stands all the time.
