C2 Windshield Trim
Old Jun 20, 2012 | 10:37 AM
VetteJohn's Avatar
VetteJohn
Default C2 Windshield Trim
'm working on getting the windshield in my '66 coupe and started by pre-fitting the SS trim. With the WS out and new clips I don't seem to be able to get the trim in so it looks right. I ran across an instruction on the Paragon site that recommends cutting a series of small Vs in the reinforcing rib to improve fit. Has anyone tried that method?
Old Jun 20, 2012 | 11:00 AM
TheSaint's Avatar
TheSaint
I took out the windshield on my car just to have a look at the window frame
I changed the weatherstrip seal, clips and screws.
I read a lot about it before i did the job. Note that i did this on a coupe and it is different clips on a coupe and convertible
I was told to use clips from Paragon. The weatherstrip seal i bought from Ecklers.
When installing a new weatherstrip the new seal it will be a bit thicker than the old one and that makes it a more difficult to put the windshield stainless trim on correct.
Me and a friend put on the stainless trim on the car before the windshield was in place just to make sure everything was fitting okay after it was removed from the car.
The trim was flush and perfect without the windshield seal.
After the windshield/seal was in place it took some careful twisting and turning to have the stainless trim laying flush and correct.
So just try a little careful twist and turn on the stainless trim and it will fit.
What makes it a little difficult to put on the stainless trim is because of the new thicker windshield seal.
If i was going to do this job now i would not put any sealant on before the windshield is in place and not do it as we did and put the sealant on the windshield seal
You should polish the stainless trim while it is off the car
Old Jun 20, 2012 | 12:21 PM
Mike Geary's Avatar
Mike Geary
I've done basically the same thing. Used a cutoff wheel to cut several slots in the rib to get the corner section to sit flush. The cuts were only maybe 75% deep in the rib to retain some rigidity and avoid folding. Took about 4 or 5 cuts and problem solved!
Sometimes, moving or adding a clip is needed to get a flush fit at the corners...
Old Jun 20, 2012 | 03:19 PM
VetteJohn's Avatar
VetteJohn
Default Thanks
Rodger and Mike,
Thanks for your insights. I was afraid to start grinding on my trim until I had someone tell me that they had done it. The idea of adding a couple of extra clips seems like a good idea too.ince I saved all my old clips I guess I'll clean them up and reuse a some of them.
John
Old Jun 20, 2012 | 07:46 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Rodger and Mike,
John
I would not recommend re-using the clips, and be sure that you get the new ones through Paragon as I think they are the only guys who sell the the correct type. As you know they are buried once the glass is in and it's a b--ch to change them. Another thing I found when I did mine was that many of the screw holes won't hold. Just re-drill 1/4" left or right from the old hole, but be very careful that they are the same depth from the frame edge.
Good Luck!
Old Jun 20, 2012 | 09:11 PM
packrat's Avatar
packrat
Default NCRS MAC Tech Session
Hi John,
Send you a PM tonight.
Page Campbell
pcampbell3618@comcast.net
Old Jun 21, 2012 | 10:16 AM
TheSaint's Avatar
TheSaint
On my car all of the screw holes held except for one.
I just did not only change the clips with Paragon clips i also put on new flat head screws for the clips
Good Luck!
Old Jun 21, 2012 | 11:51 AM
VetteJohn's Avatar
VetteJohn
Default Rodger
I've ordered both the clips and screws from Paragon.
Did you ever get your AC assembled and working?
JP
Old Jun 21, 2012 | 12:20 PM
Vette Daddy's Avatar
Vette Daddy
JP
New clips and screws for sure. Once the windshield is in place, you should be able to get the trim pcs in place without modifying anything at all. The windshield gsket from Corvette Central fit fine and was not oversized. The side pcs only need twisted slightly to get them to fit underneath the header and lower piece. Take your time and go slowly. You'll do just fine.
Old Jun 24, 2012 | 01:39 PM
TheSaint's Avatar
TheSaint
I am just missing a few parts but i will put on new brake lines and disc brakes on all 4 wheels first.
I have had the parts ready for the disc brake convertion for over 2 years so i guess it is time to finally get the disc brakes on.
It is just that i am not looking forward to replace the front to rear brake line
JP
To C2 Windshield Trim
