65 wiper question
Old Jun 23, 2012 | 11:54 AM
gr8corvette's Avatar
gr8corvette
Gr8Corvette
Default 65 wiper question
I got caught in the rain yesterday. When the wipers came to the center position, the passenger wiper caught the driver wiper and ripped the rubber from the driver wiper.
I assume this means they are not synchronized properly. How do I correct this problem?
Old Jun 23, 2012 | 12:01 PM
65GGvert's Avatar
65GGvert
Make sure in the wiper park position the passenger side wiper is installed on the shaft sitting above the driver's side like in this picture.
Old Jun 23, 2012 | 01:28 PM
BLee's Avatar
BLee
There's also a screw on the originals that allows for a small adjustment at the ends to keep them from hitting.
Old Jun 23, 2012 | 04:41 PM
65GGvert's Avatar
65GGvert
This is the adj screw BLee is talking about:
Old Jun 23, 2012 | 04:45 PM
JohnZ's Avatar
JohnZ
The arm orientation on the spindle establishes the position of the arm, and the adjusting screw touches-up the angle of the blade.
Old Dec 16, 2012 | 03:51 PM
gr8corvette
Gr8Corvette
OK, I am a procrastinator! I don't drive in the rain, so this is the first time I had to work on the wipers.
I turned the screw all the way in one direction (until it stopped). I could not get anything to happen. I then turned it all the way in the other direction (which was tightening it) until it stopped. I could not get anything to happen. I tried wiggling it, pulling it, pushing it, etc.
What is supposed to happen when the screw is turned. It may be that I am to gentle in trying to adjust it, but I did not want to break or bend anything.
Just to be sure, are both wipers supposed to be the same size. It seems things might work better if the passenger side wiper were a little shorter. I say this because it is the passenger side tip that is hitting the driver's side wiper in the middle of the driver's side wiper blade and getting tangled.
Old Dec 16, 2012 | 04:07 PM
JohnZ's Avatar
JohnZ
Assuming you're talking about a midyear (your post doesn't say), photo below shows the fine angle adjusting screw operation inside the wiper arm. Unless the single rivet that joins the flat bar to the stamped arm is corroded solid, that rivet is the pivot point that allows the angle between the two parts to be changed. If you have the wiper arms correctly positioned on the transmission splines so the driver's side blade is below the passenger side blade as shown in the Assembly Manual, the adjuster screws allow you to set the blades parallel to each other. Both blades are 15", and they won't hit each other if they're properly adjusted.
Old Dec 16, 2012 | 04:26 PM
gr8corvette
Gr8Corvette
JohnZ: Thanks for the picture. That explains why tugging and wiggling the wiper arm did not do anything. Good thing I did not tug too hard or I would have bent something.
If I am understanding the picture correctly, the center "thingie" is threaded, so turning the screw does not move the screw out of or into the wiper arm, but re-positions the thingie so that the angle of the arm changes slightly. Is that correct?
If so, then I think I need to angle the passenger arm up more and the driver's arm needs to angle down more.
Yes, the drivers wiper is on the bottom when the wipers are off.
Old Dec 16, 2012 | 04:35 PM
JohnZ's Avatar
JohnZ
Yes, that's correct - turning the screw doesn't move the screw, it moves the threaded trunnion on the screw threads, which changes the angle between the two parts.
Old Dec 16, 2012 | 06:22 PM
gr8corvette
Gr8Corvette
Thanks, that helped me understand what to do. It is now adjusted so the wipers just barely miss each other as they operate! I never would have guessed the screw was part of a trunnion; I thought it was a pressure adjustment to allow the arm to go longer or shorter. Your picture was the perfect way for me to understand.
Anyway, although it is adjusted, the best I could get it was not what I had hoped for. When turned off, it goes down properly, with the driver wiper in the bottom position, it looks like it is just barely touching the windshield chrome. However, if you pull the wiper away from the windshield and just let if fall back down, it rests at the bottom of the chrome, almost to the paint. I guess this means there is normally tension on the wiper and the chrome is acting as a stop to the wiper, so it cannot go down further. Is this normal?
Old Dec 16, 2012 | 06:49 PM
JohnZ's Avatar
JohnZ
No, it's not. You should set the wiper arm position on the splines with the windshield WET (doing it dry leaves tension in the system); that way you'll get repeatable results. The wiper arm adjustment pattern (and the note for wet glass) is in your Assembly Manual (UPC 1, sheet E4).
Old Dec 17, 2012 | 12:27 PM
gr8corvette
Gr8Corvette
I looked in the assmbly manual. If I am looking in the correct place, I do not have that sheet. I have two manuals (I bought one from Ecklers when I bought the car not knowing there was one from Mid America Corvette in the box of parts) and both assembly manuals go from UPC 1, Sheet E2, Page E63 to UPC 1, Sheet 5, Page E64. Therefore the page numbers are consequtive but Sheets 3 and 4 seem to be intentionally omitted in both assembly manuals.
Am I looking at the wrong thing?
Old Dec 17, 2012 | 04:04 PM
JohnZ's Avatar
JohnZ
Assembly Manuals were copied/re-copied and sold by many vendors, with varying quality and hand-applied page numbers; mine was from Millennium Industries, and the UPC 1, sheet E4 page has a hand-written "65" page number at the bottom. I'd scan it and post it, but my scanner picked today not to communicate with my computer; maybe someone else can post sheet E4.
P.S. The photo in post #2 is an excellent example of properly installed wipers.
Old Dec 21, 2012 | 07:21 PM
gr8corvette
Gr8Corvette
TTT; anybody?
Old Dec 21, 2012 | 07:53 PM
65GGvert's Avatar
65GGvert
TTT; anybody?
Old Dec 22, 2012 | 11:47 AM
gr8corvette
Gr8Corvette
Thanks!!!
Old Dec 22, 2012 | 12:10 PM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
Advice that I received a couple of years ago from John H.:
I have my blades set so the tip of the driver's side blade is 1" above the top edge of the reveal molding, and the tip of the passenger side blade is 2" above the top edge of the reveal molding, and the blades are parallel to each other when parked (use the slotted adjustment screw on the top edge of each arm to adjust their angle).
To 65 wiper question
Old Dec 22, 2012 | 02:04 PM
gr8corvette
Gr8Corvette
What is "reveal molding"? Is that the chrome strip around the windshield?
Old Dec 22, 2012 | 02:09 PM
JohnZ's Avatar
JohnZ
Yes - the exterior stainless moldings are the "reveal" moldings, and the interior moldings are the "garnish" moldings.
Old Dec 22, 2012 | 02:42 PM
TheSaint's Avatar
TheSaint
Never had the problem but the picture and what the screws are for is stored on my computer under Corvette C2
This is great John
By Michael S. Palmer | 2026-06-03 11:00:24
