Flag emblems
Old Jul 1, 2012 | 03:31 PM
36couper's Avatar
36couper
Default Flag emblems
I made an intro this morning......
I just bought a '63 convert. The previous owner filled in the holes in the front fenders for the flag emblems.
Does anyone know exactly where and how I can re-install them.
I know I will have to drill some holes but I want them positioned correctly and attached securely.
Thanks in advance.
Old Jul 1, 2012 | 03:38 PM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Thanks in advance.
You should be able to look on the back side and see where the holes were. Probably can drill them from the inside. (There are two different stud spacings on the thin and thick emblem studs. Be sure which yours is.) If your car is already painted, tape off the outside so the drill doesn't flake the paint.
62Jeff's Avatar
62Jeff
Welcome and congratulations!
I'll put this out there but I can't recall if 1963 and my 65 will be identical.
Old Jul 1, 2012 | 06:27 PM
36couper's Avatar
36couper
Thanks for the quick reply. Both great suggestions!
Old Jul 2, 2012 | 09:49 PM
36couper's Avatar
36couper
My '63 will be sharing space with my '36.....BBC powered of course!
Old Aug 11, 2012 | 11:53 AM
36couper's Avatar
36couper
I've started out by masking the area where I need to drill holes for the emblem. For some reason it doesn't look exactly like the photo 62jeff posted.
Can anyone tell me if the '63 and '65 fenders are identical?
Old Aug 11, 2012 | 12:16 PM
Rich Yanulis's Avatar
Rich Yanulis
OK
I just went out to the garage and measured my VERY original '63.
1 1/2 inches to the bottom of the V, just like Jeff's picture.
However, they are centered 15 inches forward of the fender edge.
FWIW..........one is 14 7/8 the other is 15 1/8. This shows the inconsistency in typical factory production done 49 years ago.
Old Aug 11, 2012 | 12:34 PM
vt65's Avatar
vt65
just measured, same on my '65, likely the '63 / '64 difference is because of the side vent centres
Old Aug 11, 2012 | 12:53 PM
36couper's Avatar
36couper
Fantastic! Thanks. I'm glad I didn't start drilling holes yet.
Will include pictures when I'm done.
Thanks Gents.
ac
Old Aug 11, 2012 | 05:55 PM
36couper's Avatar
36couper
Success. The drivers side was a breeze but the passenger side was a bitch. Had to pull the battery after I dropped the nut. Then the space between the blower motor and the emblem tab was tight. After about an hour, finally got the nut started and tightened it with an open-end wrench. Thanks again for your help. Here are some pics:
Yes, my garage is carpeted
Old Aug 11, 2012 | 06:01 PM
PaulUptime's Avatar
PaulUptime
Arrrgggh! You put them on the wrong side!
Just kidding....
Nice '63 convertible you got there!
From the owner of a '65 convertible just a little to the east of you.
Old Aug 11, 2012 | 06:12 PM
vt65's Avatar
vt65
nice job Coup, man those lic. plate lights are some bright! From the owner of a '65 convertible just a little to the South of you.
Old Aug 11, 2012 | 06:15 PM
36couper's Avatar
36couper
You just about had me! Phew!
Old Aug 11, 2012 | 06:18 PM
36couper's Avatar
36couper
I'm not sure why the plates are so bright. Maybe because they are new. At least it hides the plate number
Old Aug 11, 2012 | 08:40 PM
PaulUptime's Avatar
PaulUptime
I decided to drill and install those stinkin' badges on my car once before. Screwed 'em up too by putting one higher than the other. Bugged me then but was easier just to let it go, another reminder not to take it too seriously. This is all about the fun, after all. If you're chasing perfection you have no business being around Corvettes (IMHO) or if you are, you are doomed to a hobby of misery.
Al... you, Rob and I should do a C2 convertible cruise some time this fall. It's our favourite time for cruising wine country.
Whadaya say Rob.... in???
Old Aug 11, 2012 | 09:02 PM
vt65's Avatar
vt65
yes good idea, we could meet up in Hamilton somewhere along the QE
Old Aug 12, 2012 | 12:36 PM
36couper's Avatar
36couper
Believe me, I'm no perfectionist. I enjoy driving the car more than working on it. I'd be up for a C2 cruise this fall!
Old Aug 12, 2012 | 07:10 PM
MAD IN NC's Avatar
MAD IN NC
Crowd Plow For Now
Success. The drivers side was a breeze but the passenger side was a bitch. Had to pull the battery after I dropped the nut. Then the space between the blower motor and the emblem tab was tight. After about an hour, finally got the nut started and tightened it with an open-end wrench.......
65's are the same.... best off doing it from underneath (on lift) with out the splash shield... trust me - just did it last weekend on my 65......
To Flag emblems
