Recently purchased '64 coupe and while going over discovered slight freeplay in drivers side rear hub between hub spindle and spindle flange. This connection has a nut with a cotter pin keeping it in place. I have ordered manuals for car but they are not in yet, therefore I'd really appreciate it if anyone could tell me the torque amount that this nut should be tightened to. One other question is, if I do retorque this nut will I be changing any pressures on the wheel bearings? Thanks in advance in any info you can give me. Mike
The correct torque is 100 ft/lb plus whatever is required to align the cotter pin holes, but if you find that the existing torque is below this value it would infer incorrect assembly or excessive deterioration.
If the nut is already at the correct torque value, it's time for a rebuild.
The assemblies where originally said to be sealed for life, but experience shows that they should be disassembled and inspected every 30-40K miles or so.
Mike, I removed the nut and it easily came loose with little effort on a wrench (socket). No way it was 100ft/lbs. Just so you know this car recently went through a complete restoration (supposively) by previous owner, and everything from brakes, bushings, etc look new.
If I torque this nut to 100ft/lbs will I be placing excessive pressure on the bearings/races, or the nut to spindle has nothing to do with that?
If the nut came loose that easily, I'd suspect that the bevel washer used under the nut (assuming there was one there) gave out on you. I wouldn't retorque the nut without installing a new washer. I think I've also mentioned that aspect of your problem in your other thread regarding your loose spindle. But, it could also result from a problem with the bearings and/or spacers as well I'd think. And, if the car has been run for any appreciable length of time with play in the splined connection, it's also possible that it has wallowed out the splines to an extent.
I'd send it in to be rebuilt. My $0.02
The nut has everything to do with keeping the outer bearing, spacers, inner bearing, washer and flange very tightly assembled eliminating any possible relative movement. This is in addition to the tight fit of the bearing races themselves. Being that someone has recently been 'restored' there's no telling what's going on without disassembly.
I agree that the splines may be worn from incorrect torque. I'm going to replace that washer and do a retorque and feel it out locally for a few miles and then check it again. If it doesn't feel, look, or sound right I'll have it redone. Thanks again for your help. Mike
IMHO; after you retorque the spindle nut check the in and out play of the spindle. spec should be .001 to .008 or .002 to .007. A drum brake can tolerate the high side of the spec. This end float/in and out play is important.
Brgds,
Rene
I should have mentioned it earlier, but you can pull the drive flange from the assembly once the nut and washer are removed. The flange should slide right off, give you a chance to inspect the splines on the flange at least. Not sure, but you may be able to see the splines on the spindle/axle as well with the flange removed.
The remainder of the assembly is a press fit, however. It has to be pressed apart for disassembly.
I'm outta here, let us know what you eventually find . . . .
I removed nut, washer, and flange and don't see any obvious signs of wear. Washer is very thick and slightly concaved, and was installed with concave face facing in. I wiped them down and reinstalled with the intention of retorqueing to spec, but as soon as I tightened 10-15ft/lbs, assembly did not want to turn and felt like bearings were being pressed into races. Sort of like if you were adjusting front wheel bearings without any freeplay and overtightened. Definitly not right, so I didn't tighten any more.
I walked away at that point, and will wait for my manuals to arrive before going further. Perhaps it was assembled using disc brake specs or just not assembled correctly. I'm in the dark until I have manuals to refer to, so I'll just see if I can find other possible problem areas that may need attention. Sure appreciate the help, Mike.
The specs and process are the same for both drum and disk brake cars. My guess is the the previous owner either put in the wrong thickness of shim- or no shim at all. It's not unheard of.
That's sure what it sounds like. And that would explain why the assembler didn't tighten the castellated nut per specifications. Sounds like he may have left it loose so as not to bind the spindle. In any event, it sounds like it's gonna have to come apart to see exactly what the problem is, be set up again properly, and perhaps need new bearings as well.
That's gonna require pressing apart. Again, I'd send the assembly off to be rebuilt.
IF you do not have the proper end play and the spindle will not turn, stop. Now you must decide if you want to set up the spindle yourself or farm it out. Special tools are required.
Keep us informed and consider checking the other side.
On another note: see if the spindle will pullout of the spindle support by hand or a SMALL amout of force. Sometimes the spindles are turned for a slip fit of the bearings.
Brgds;
Rene
Brgds;
Rene
I tried pulling spindle out by hand with nut, washer, and flange removed. It came out around almost an inch and stopped. I didn't try pulling it any further. I'll try again tomorrow. I'll definitely have to check the other side, as now I don't really trust anything on car.
If you have access to a slide hammer you could attach it to the wheel studs and gently tap it out, or tap it out from the flange side with a thread protector on the spindle. If it moved an inch by hand it should come out. Once it is out remove the seals from the spindle support and then remove the inner races of the bearings, the spacer and any shims. Inspect everything. You now have a good visual of how the bearings inner races are spaced with the spacer and shims. Let us know the condidtion of the bearings [inner and outer races] and the condition of the spindle and the condition of the grease. I.E, old/caked/burnt.
Brgds,
Rene
Brgds,
Rene
I do have a slidehammer. I'll give that a try tomorrow. Thanks
The brakes were done 2 months prior to me bying the car. Less than 50 miles put on it . So new rotors/calipers and pads. So grease looked clean/fresh so assume they were repacked
I think you're in the wrong thread - previous post was 2012.
