pilot bushing part #
Old Jul 16, 2012 | 12:07 PM
Brumbach's Avatar
Brumbach
Default pilot bushing part #
Anyone have the part number for the pilot bushing to convert powerglide to muncie? 68 327.
Thanks,
Bill
Old Jul 16, 2012 | 12:14 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Old Jul 16, 2012 | 12:33 PM
Vet65te's Avatar
Vet65te
GM still has them but they aren't readily avalable, I'm in Northern California and the bushings were sent out from Michigan I believe.
Mike T.
Old Jul 16, 2012 | 12:39 PM
Brumbach's Avatar
Brumbach
Originally Posted by KC John
I've got that one ready to replace but the existing bearing or bushing appears to be shorter than the 656. Maybe half as much.
Old Jul 16, 2012 | 01:01 PM
Brumbach's Avatar
Brumbach
Closer examination (put my glasses on this time) the first half of the pilot bearing is wobbled out. Wonder what would cause this?
Old Jul 16, 2012 | 01:15 PM
DansYellow66's Avatar
DansYellow66
Unless I misunderstand your description it's probably just routine wear. The input shaft nipple may not go all the way through the bushing and that is where the wear is concentrated.
Old Jul 16, 2012 | 01:21 PM
Brumbach's Avatar
Brumbach
Yep, I think you're right! I managed to get it out with a tap and bolt. Apparently the shaft nipple rides on the first half of the bearing. Anyway, is it necessary to soak the new bearing in oil before installation? Seems like the last time I installed one, I actually boiled it in oil. Waste of time or needed?
Old Jul 16, 2012 | 02:26 PM
JohnZ's Avatar
JohnZ
Don't do anything to it - just install it; it's Oilite bronze, and the required lubrication is already there.
Old Jul 16, 2012 | 05:25 PM
Desertvette's Avatar
Desertvette
Default Pilot bushing for powerglide crank
Bill ,if your looking for a conversion bushing ,your going to have to get a Dorman 690034. The powerglide cranks never got the final reaming and have about .029 smaller ID.
I don't know if the Dorman bushing is made of Olite but I have used them without problems.
The diemensions are standard bushing .593x 1.095 and the conversion bushing .593x 1.065. You need a .002 to .003 interference fit, so you will have to measure the crank ID
There's also a Turboglide buhing Dorman p/n 690035 with a.593x 1.073.
If your set on the Olite bushing you will have to turn one down as necessary
LOL
Bob
To pilot bushing part #
