Water spots
Old Aug 4, 2012 | 01:53 PM
maggiesadie8525's Avatar
maggiesadie8525
Default Water spots
I can't seem to get the water posts off the windshield does anyone know what to use. Would appreciate it. Thank you
Old Aug 4, 2012 | 03:09 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
CLR should work, they are probably hard water spots (calcium).
Another way to go is with "Mister Clean Magic eraser". My wife recently found out that it works great for cleaning our shower door glass. She said it comes off like magic. Give it a shot.
Old Aug 4, 2012 | 03:21 PM
maggiesadie8525
Originally Posted by kc john
clr should work, they are probably hard water spots (calcium).
Another way to go is with "mister clean magic eraser". My wife recently found out that it works great for cleaning our shower door glass. She said it comes off like magic. Give it a shot.
thank you john
Old Aug 4, 2012 | 03:29 PM
Dave Tracy's Avatar
Dave Tracy
You could try vinegar or a clay bar.
Old Aug 4, 2012 | 10:23 PM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Spray on Widex, wipe off with newspaper print.
Old Aug 4, 2012 | 10:24 PM
Redbird's Avatar
Redbird
Spray on Windex, wipe off with newspaper print.
Old Aug 5, 2012 | 09:44 PM
MarvBarrish's Avatar
MarvBarrish
You can clay bar clean it off as well.
Old Aug 5, 2012 | 09:45 PM
maggiesadie8525
Originally Posted by marvbarrish
you can clay bar clean it off as well.
thank you marv
Old Aug 6, 2012 | 08:44 PM
ragtopman's Avatar
ragtopman
St. Jude Donor '10-'11
If none of the above work, 'cerium oxide' is what is used to buff out very minor scratches in windshields, so it should work for getting out water spots.
Old Aug 6, 2012 | 09:48 PM
Billygold's Avatar
Billygold
Default Water spots
Bob Ami powder used to have a GM part number if I remember correctly.It should be available in any good supermarket. I have used it to clean up windshields for 40 years. It takes the film and spots off without doing any damage to the glass. Bill Gould
Old Aug 6, 2012 | 10:46 PM
Plasticman's Avatar
Plasticman
Think that is "Bon Ami".......and it is the Kitchen and Bath Cleanser (they also sell a glass cleaner, but for hard water spots, that won't do you any good).
I have used the Bob Ami in the past for hard to remove spots on glass, but I marked on the container: "Safe for glass, but use care" If I remember correctly (been a long time ago), I saw very fine scratches after using it. It is supposed to be safe for all surfaces (fiberglass tubs included), so I may just of not been careful enough to keep the surface wet enough, or I did not clean it properly before using the Bon Ami.
Plasticman
Old Aug 7, 2012 | 11:09 AM
64tux's Avatar
64tux
try vinegar and water. it works on car as well !!
Old Aug 7, 2012 | 12:11 PM
maggiesadie8525
Originally Posted by billygold
bob ami powder used to have a gm part number if i remember correctly.it should be available in any good supermarket. I have used it to clean up windshields for 40 years. It takes the film and spots off without doing any damage to the glass. Bill gould
thank you bill
Old Aug 7, 2012 | 07:26 PM
MCMLXI's Avatar
MCMLXI
Finalist 2022 C1 of the Year - Unmodified
2020 C1 of the Year Finalist - Unmodified
C1 of Year Finalist (stock) 2019
I had the same problem. Windex, 409, vinegar, all failed - but Mcguiars Quick Glass Cleaners took care of my stubborn water spots
stall's Avatar
stall
"MOTHERS" now makes a Water Spot Remover; I bouught a tube this week at Autozone and was pleased with it.
Old Aug 7, 2012 | 07:31 PM
maggiesadie8525
Originally Posted by blu72
i had the same problem. Windex, 409, vinegar, all failed - but mcguiars quick glass cleaners took care of my stubborn water spots
thank you so much
maggiesadie8525
Originally Posted by stall
"mothers" now makes a water spot remover; i bouught a tube this week at autozone and was pleased with it.
thank you
To Water spots
