Fuel Pump question
I just came upon a frustrating situation: My Fuel Pump recently gave up the ghost so I got a new one. As usual I dinked around with other stuff (mostly fishing and golf) for a few weeks until I got the itch to drive the vette...so I decided to put the fuel pump in which brings me to my question.
After installing the pump I went to reconnect the short piece of rubber/flexible fuel line from the "nipple" on the pump to the steel gas line and now the flexible rubber hose "kinks" causing the car to run rough due to lack of fuel. I've tried various lengths of rubber hose and different configuations of loops etc. but cannot avoid the hose kinking...which now leaves me wondering if the "nipple" on the bottom of the fuel pump is pointed in the wrong direction.
A couple of items:
Admittedly, I bought the fuel pump from a local automotive parts store and is supposedly correct for my engine.
I haven't changed anything else so the only difference to date is the pump but I don't have the old fuel pump to compare.
I've looked at the few books I have (Nolan Adams, AIM, etc.) and I just can't find a good enough example of what the bottom of a correct fuel pump should look like.
Any help or thoughts would be much appreciated...thanks
car is a 66' with 327 and automatic trans
I have a 1967 small block car and the replacement AC DELCO #40503 fuel pump required that I use a longer hose and loop it in a small semicircle from the steel fuel line DOWN to the fuel pump connection. It has a slight "high spot" in the rubber hose, but it has not affected pump operation in any way.
Larry
A couple of items:
Thanks for the pics...I have an early 66 (build date Sept. 65). I've been looking on line at fuel pumps from several of the dealers out there, i.e. LIC, ZIP, Ecklers, etc. I can get the fuel pump I need from most but the question I have is "Do you know if one also has to purchase the "Nipples" to screw in to the fuel pump? Just not clear in photos and product descriptions.
Thanks, and no more silly questions
On page 54, looks like you need part nos. 27 and 5034S shown in the diagram in the upper right:
https://www.paragoncorvette.com/corv...talog/c2/#/54/
I bent a 3/8" chunk of steel fuel line and put that in place.
The first photo shows an AC hard line, and two bent fuel line sections.
I used the one on the far right, but cut another inch or more off each end.
Second photo shows it installed.
I know it's not correct, but it solved my kinking problem.
Jim
