Making some 56 axles.
After putting a 62 axle alongside of the ruined 56 axle, it became apparent that the later axle could be modified to fit. It appeared that the only difference in the axles, was the shoulder behind the wheel flange. The later model axle measured about .850" from shoulder to flange, while the 56 axle measured about .600. The length of the axle was then same, as was the OD of the axle where the bearing presses on. We took the 62 axle to a machinist, and he turned the shoulder down to the .060 width, and the axle worked like a charm. Luckily, the retainer was not completely destroyed, as it is a unique part, so we could re-use it.
Below are some pics of the 56 axle, and another 62 axle out of my stash. It is easy to see the difference.
Hopefully, this will save some poor soul the aggravation of trying to find some 56 axles, as they are rare as hens teeth!
Regards, John McGraw
Note to John McGraw,, i am eternally grateful for all your help.
Bill
I guess to use these early axles on later models, you
would have to use a .250 spacer to make the bearing
spaced correctly.
Later
Tony
Smoke came out of my calculator and it shut down.
Bill
