Stance
How much fuel is in the tank will affect the "look". Was it full or empty when you took the picture? Also, without the spare (and carrier), that will add some more wgt. to bring it down in the rear.
Plasticman
. All performance cars should have at least a slight rake to them - looks more agressive and purposeful... and just plain.... better.....
Plus, every little bit lower you go, acts like increasing the size of your sway bars which results in less body lean. More rake also equals less front end lift, for which the stingray body needs all the help it can get.
"*** drag'n" is for lincolns and lowriders..... (OK, and 60's Gassers
