396 belts with PS
396 belts with PS
i am having dickens trying to figure out the belt and pulley arrangement for 396 with PS. The alternator mount bracket puts the alternator pulley 3 grooves out from the block on the crank pulley,past the outer groove on the two groove water pump pulley (the PS pump uses the second and third groove on the crankpulley). Unfortunately my AIM does not cover the 396, and the 65 factory manual 396 supplement does not show it. Corvette suppliers only list two groove water pump pulley, not a 3 groove, can anyone advise?
also, what about the inner grooves on the crank and water pump, is there a belt? is it tight no idler or anything/
the alternator is driven with a short belt from the steering pump and the inner groove on the water pump is fitted with a short belt from the balancer and there is no adjustment on that belt, the outer groove on the balancer drives the ps pump
dunno if the 65 is the same or not......hope this helps....
Received 1,858 Likes
Your '65 Assembly Manual shows this L-78 arrangement (and all the parts) in section N40, sheet 7, and in View "A" on that sheet.
the two groove ps pump pulley is around 150.00 alone i think.....
