Replacing Fuel Line Parts
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
'64 327-300, with electric fuel pump already installed. Has 3/8" or 5/16" rubber hose that goes from the fuel tank to the electric pump (mounted just rear of passenger rear tire), then to a fuel filter, then a few extra feet and back to original fuel line.
I am replacing the fuel filter and installing a fuel pressure regulator and a fuel pressure guage. This is in response to a stuttering/bogging/delay problem I am getting when I try to mash the pedal to the floor. The valuable info I got from the forum here a couple months back said to install the regulator. Figured I would do the other stuff while I was back there.
How should I go about this? What to do first? How do I stop/plug the fuel flow once I get the fuel filter off? What to make sure to do or avoid? (No smoking will be first on the list of don'ts).
![](/forums/images/ranks/11k.gif)
Received 1,847 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I'd remove the electric pump, regulator and filter and put a pump on the engine that pumps the right pressure. That's not hard.
Electric pump is there because of vapor lock.
I put the regulator and pressure gauge on in about an hour and a half. No biggie. Seems to run better, but not perfect. Should the pressure be at 5 lbs.? Regulator only goes to 5.5, so I don't have much room to go up.
