Heat Riser Valve
Old Oct 4, 2012 | 11:36 AM
64Corvette's Avatar
64Corvette
Default Heat Riser Valve
Questioning if my heat riser valve is working properly. After the engine warms up in what position should the counter weight on the heat riser be to indicate that the valve is open inside the exhaust? Should it be horizontal or should the **** be in a more downward position for the flap to be open? I am going to drive it see if it changes a little later on. How many of you even have a heat riser valve still on your car? Thanks
Old Oct 4, 2012 | 11:42 AM
1snake's Avatar
1snake
Down is open, up is closed. I always cut the flap off the inside so it looks original and the stock exhaust still fits correctly.
Jim
Old Oct 4, 2012 | 11:44 AM
EDinPA's Avatar
EDinPA
I removed it. The car now has EFI.
Old Oct 4, 2012 | 11:45 AM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
The counterweight should be in the downward position to show that the valve is open. It opens when the spring gets hot and releases the tension. I would think most cars still have them. Spray some lubrication on the shaft if it's stiff.
Old Oct 4, 2012 | 10:58 PM
mid-year crisis's Avatar
mid-year crisis
Most pipes would require either the valve or a similar spacer in it's place to fit correctly. I gutted mine then tapped the hole in the housing and ran a bolt into it.
Old Oct 5, 2012 | 12:58 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Just wire it permanently open with some stainless steel mechanic's wire and forget about it. Did it to mine 5 years ago.
Old Oct 5, 2012 | 08:49 AM
5869vette's Avatar
5869vette
My `64 was running a little hot , discovered the heat riser was
froze half shut. Ordered a 2 1/2 in spacer from Paragon.
problem solved.
Tony
To Heat Riser Valve
