C1 indicator stalk not staying down
Hello Frankie,
I hope you are doing well!
I have just a question about the turn signal harness switch routing. The wires are meant to go inside the column trough the long hole near by the hub and gets out at the same place as the horn wire?
Thank you, regards.
Ferry
Thank you, regards.
Ferry
