66 BB radiator question
Old Oct 8, 2012 | 09:42 PM
LSUvetteguy's Avatar
LSUvetteguy
St. Jude Donor '10
Default 66 BB radiator question
My radiator has been giving me problems for a while so I bought a replacement core from one of the well known vendors. I've had it for a few months and decided to start the replacement today. When I removed the core from the box I noticed two holes on each end in the top brace. On each end there was a rectangular hole with a square hole about an inch away. My old radiator, which I thought was original, has no holes in the top brace. I checked with a friend who has a 66 BB and his original(?) radiator doesn't have any holes. I checked the judging manual and it says the holes should be there. Anyone know if both styles were used?
Old Oct 9, 2012 | 01:38 AM
zpletcher's Avatar
zpletcher
I will look at the one I pulled a few months ago.
It is in my storage shed.
I put in the De Witt's Aluminum replacement one with epoxy black paint
and it fit perfectly.. Man, it sure runs cooler....
Living down here in hot weather it is the way to go..
This motor won't even start to get hot, even stuck in bumper to bumper traffic on a hot summer day!!
Cheers, Zale
Old Oct 9, 2012 | 03:37 PM
JohnZ's Avatar
JohnZ
Only one style was used originally - with the holes as you describe (and shown in the photo below); any radiator without the holes in the tie bar is a replacement.
Old Oct 9, 2012 | 10:02 PM
LSUvetteguy
St. Jude Donor '10
Thanks for the information. I got the new core put in today using the bar with the holes and should have it in the car tonight. A short test ride and we're heading down to the big "Cruisin' the Coast" show.
Old Oct 10, 2012 | 09:46 AM
Avispa's Avatar
Avispa
John showed the correct radiator. If you still have heat problems, but want to keep a brass radiator with stock side tanks, there is a high efficiency core available that your friendly radiator shop should be able to get for you. The stock radiator has four rows of tubes spaced 9/16 inch apart and has 12 fins per inch between the tubes. The high efficiency core has five rows of tubes spaced 3/8 inch apart and has 14 fins per inch, and will fit to the stock tanks and will allow correct radiator mounting. It makes a bigdifference in engine temperature.
To 66 BB radiator question
