65 Trim Code
Old Oct 9, 2012 | 07:01 PM
Woodie 65's Avatar
Woodie 65
Navigator
Default 65 Trim Code
450A..... The color for 450 was white. But I don't understand what the (A) is for. Can you guys shed some light.
Old Oct 9, 2012 | 07:16 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I take it you have a A.O. Smith body.
Old Oct 9, 2012 | 07:59 PM
Woodie 65's Avatar
Woodie 65
Navigator
Not sure what that means. This is a car that my Dad bought 28 years ago and I'm starting to get back on it.
Old Oct 9, 2012 | 08:04 PM
Nowhere Man
Can you post all the info on the trim tag
Old Oct 9, 2012 | 08:11 PM
62Jeff's Avatar
62Jeff
Welcome Woodie.
You can use this site http://www.stl-vettes.com/65Vette/tr...ag_display.htm to decode your trim tag.
Old Oct 9, 2012 | 08:16 PM
Woodie 65's Avatar
Woodie 65
Navigator
450A F-F Paint
The number on the other GM Tag is 194375S105938
Old Oct 9, 2012 | 08:35 PM
Woodie 65's Avatar
Woodie 65
Navigator
62Jeff It's not working for me and I think it's because I have a Mac
Old Oct 9, 2012 | 08:37 PM
62Jeff's Avatar
62Jeff
Ok, bummer.
THere should be more numbers on your trim tag than you posted. As Nowhere Man mentioned, please post all numbers on your tag and he can decode it for you.
Old Oct 9, 2012 | 08:41 PM
Woodie 65's Avatar
Woodie 65
Navigator
Style 19 437
Body A-995
Old Oct 9, 2012 | 09:38 PM
Nowhere Man
alright you have a Nassau Blue coupe with white and blue interior. or white seats and door panels with blue carpet and dash pads. (very nice color combo by the way) your car was built approximately January 4, 1965. there should be a digit combo on the upper left of the trim tag that reads F4. it is a A.O. Smith built body built in Ionia MI. that means the body was assembled, painted and glass installed, and then shipped via rail car to St. Louis to be finished. that was the 994th body built by A.O. Smith style 19 437 means its a coupe. also the A behind 450 means its a base unit without power windows, automatic, and the 36 gallon fuel tank
Old Oct 9, 2012 | 09:43 PM
PaulUptime's Avatar
PaulUptime
I believe Keith (Nowhere Man) is correct (as usual!) that the A indicates the body was manufactured by an outside contractor (in Ionia MI) named A.O. Smith.
My '65 convertible's Trim Tag states:
A29
STYLE 19 467 A-195 BODY
TRIM STD U-U PAINT
VIN 19467 5 S100621
Decoded: 19467 Model/Type:Corvette/Convertible
S100621: 620th car off the line
A - indicates Aug'64 Manufacture date, but last car in Aug'64 was #100227 so I figured this just means AO Smith build the body in August and the car was assembled in early September (8th, according to the build date finder.)
You can find this build date finder at
http://www.stl-vettes.com/65Vette/bday.htm
This is where I found my car's build date actually matches my birthday. While this makes it exactly one year older than me, it's still cool because we're both '65s!
Said JohnZ in a post from '05: http://forums.corvetteforum.com/c1-a...-trim-tag.html
A.O. Smith bodies were fully painted, but only partially trimmed - they only had glass and weatherstrips to keep the water out during shipping; the rest of the interior was installed at St. Louis. A.O. Smith bodies weren't used "when they were running low" - 50% of the bodies came from A.O. Smith (the St. Louis Body and Paint Shop only ran on day shift after January, 1964).
and even more detailed here:
A.O. Smith (Ionia, Michigan) built 50% of the midyear Corvette bodies starting in January, 1964, and rail-shipped them to St. Louis for final assembly. Link below will take you to an article I wrote on it.
http://www.lbfun.com/warehouse/tech_.../A.O.Smith.pdf
From: http://www.secondchancegarage.com/pu...te-buyers1.cfm
The trim tag also shows you the date code for the body and the body supplier. An "S" indicates a St Louis body, an "A" indicates an A.O. Smith body. The time built code is stamped under the "Chevrolet Div." header at the top of trim tag. It's a simple code with the letter representing month and the two numbers the date of assembly. The St. Louis cars start with "A" for September while A.O. Smith uses "A" for August as they didn't have a plant shut down period for retooling.
Old Oct 10, 2012 | 12:51 AM
Woodie 65's Avatar
Woodie 65
Navigator
Thanks guys I really appreciate all the help. I'm just starting on the car and wanted to do a bunch of research first. I'll post a pic for you guys tomorrow.
Old Oct 10, 2012 | 03:44 PM
Woodie 65's Avatar
Woodie 65
Navigator
[IMG][/IMG]
Here she is guys...... Cars been sitting for about 10 years or so. I have some brake work and a few other things to do to get her back on the street but it shouldn't take to long. My Dad bought this car about 26 years ago and did alot of work to it then but didn't drive it much. He's left it up to me to take care of her so she gonna get some long needed love. Let me know what you guys think.
Old Oct 10, 2012 | 03:49 PM
Woodie 65's Avatar
Woodie 65
Navigator
Also meant to add this car has the original motor, trans, and rear end.
Old Oct 10, 2012 | 03:53 PM
PaulUptime's Avatar
PaulUptime
Nice Coupe/project you have there!
....'cept what's with the '66 badge on the front and int/ext colors being different from what Nowhere Man decoded?
Old Oct 10, 2012 | 03:57 PM
Woodie 65's Avatar
Woodie 65
Navigator
He changed the colors from what the originals were. He was always a big fan of the white with red interior.
Old Oct 10, 2012 | 05:07 PM
Nowhere Man
its a shame because blue with white and blue interior is one of the best combos for a mid year
Old Oct 10, 2012 | 09:24 PM
JohnZ's Avatar
JohnZ
"450A" simply means it's a coupe (450B would be a convertible). '65 A.O. Smith trim tags didn't have the full 2-character Trim ECL suffix like St. Louis trim tags did - they only used the first character. In '66 and '67, A.O. Smith trim tags didn't use either the "A" or the "B" - only the trim number, with no suffix at all.
To 65 Trim Code
