Differential interchangeability
Old Oct 23, 2012 | 07:40 PM
camaro_haehn's Avatar
camaro_haehn
Default Differential interchangeability
Hey forum members, I need your help. Are there any GM differentials internal components that interchanged with the Corvette (63-79)? Nova / Camaro / Chevelle ? Pinion shaft? ring gear? differential case carrier ? differential pinion? drive pinion?
Picked up a used one and need a diff case carrier and might need to change out some other pieces parts.
Thanks for your help guys Craig
Old Oct 24, 2012 | 05:03 PM
JohnZ's Avatar
JohnZ
The Corvette diff is completely unique to that application; I think the only common parts might be the ring gear bolts.
Old Oct 24, 2012 | 05:20 PM
camaro_haehn
I was afraid of that, guess I just have to keep traveling to the swap meets, combing Craig's list and keep my eyes open for the parts. Appreciate the information .
Regards Craig
Old Oct 24, 2012 | 06:06 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
What rear are you looking for.
Old Oct 24, 2012 | 06:27 PM
4 Speed Dave's Avatar
4 Speed Dave
For parts call Tom at Toms Differentials he is a no BS guy and he knows Corvette rear ends inside and out.
http://www.tomsdifferentials.com/
Old Oct 28, 2012 | 08:03 PM
camaro_haehn
I have most of the pieces parts to complete a C2 / C3 differential except the diff carrier. I have been gradually getting pieces together and I am still in need of a posi carrier. Will a C4 diff carrier fit a C2 / C3? A new carrier is out of the question, $500 I am trying to piece a posi together, and learn a little bit in process. Any help will be appreciated. All of your input is greatly appreciated. Regards Craig
Old Oct 28, 2012 | 08:27 PM
Nowhere Man
A C4 rear will not work in a C2/3 rear. To find a used posi unit from a C2/3 rear should not be that hard to find and that expensive if you don't care about a. Dates and codes
Old Oct 28, 2012 | 08:36 PM
JohnZ's Avatar
JohnZ
Nope. C2/C3 posi units were made by Eaton, C4 posi units were made by Dana; they share zero parts.
Old Oct 28, 2012 | 10:18 PM
camaro_haehn
Thanks guys, I will keep looking for a C2 / C3 posi carrier. Regards Craig
Old Oct 28, 2012 | 10:21 PM
66jack's Avatar
66jack
How "expensive" or "not" are you talking about?
To Differential interchangeability
