VIN Help
Old Nov 6, 2012 | 03:55 PM
Bearzerker's Avatar
Bearzerker
Default VIN Help
I have a 66 C2 and was wondering how do I find out details on my car...
like if the engine was the 390hp 427 or the 425hp 427
VIN # 194376S114786
trim code 978AA (Laguna Blue exterior) with 414AG (Bright Blue Interior)
Last edited by Bearzerker; Feb 26, 2013 at 03:03 PM. Reason: adding and correcting
Old Nov 6, 2012 | 04:07 PM
66jack's Avatar
66jack
Whats the other stampings on the engine pad, that are by the VIN....that will tell more about the engine
Old Nov 6, 2012 | 04:09 PM
JohnZ's Avatar
JohnZ
my VIN # is
194376S114786
There's no information in the VIN or the trim tag about the driveline. What's the block casting number and date, and what's stamped on the block front pad?
Old Nov 6, 2012 | 05:04 PM
66jack's Avatar
66jack
have to go to work now...
but i hope these pictures help some and work
thanx for awesomely fast replies guys...
https://www.dropbox.com/s/edwl1ab3r2...2014.18.36.jpg
https://www.dropbox.com/s/fq4t6i54qd...2014.18.48.jpg
https://www.dropbox.com/s/ycjl73i7g1...2014.18.58.jpg
No help...Like JohnZ asked....whats on the engine pad?
Old Nov 6, 2012 | 05:29 PM
oldgold49er's Avatar
oldgold49er
Default 66
I think the only way to tell for sure if your car was even a BB car is to have documentation, or the engine block.
BB hoods are everywhere.
My understanding is that BB cars had several unique features such as a rear sway bar, bar clamps instead of round u-clamps on the 1/2 shafts, fuel line has a 90deg. bend entering the fuel pump. rear end has a letter designation for BB cars maybe AU?, 80lb oil press gauge,battery on the right, hood support on the left. All L72's also have Trans. ignition, and I do not think an auto. trans. or Ac were available(L72). What is the redline on the tach?
Old Nov 6, 2012 | 06:26 PM
RestoMike's Avatar
RestoMike
From: Livin' large and havin' fun in wonderful Oklahoma
All changeable items.
Old Nov 6, 2012 | 10:25 PM
KC66's Avatar
KC66
Wrong tac and battery on wrong side for BB. I dont think anyone would go throught the trouble to make it from a BB to a SB and move the battery and change the tac. Maybe a SB to a BB, but not the other way around.
KC
Old Nov 6, 2012 | 10:48 PM
62Jeff's Avatar
62Jeff
ok...
so this could be a good thing as the SB that's in it could be the original engine.
Is there anyway to verify this new information? and did they have factory installed AC in the small block for the 1966 model year...
I was told only the 390HP 427 had the factory AC
Yes A/C was available in the small blocks. The dealer told you incorrectly.
Look for the engine stamping on the flat pad just foward of the passenger side head. It is part of the block deck, the same deck a head gasket is installed on. Hopefully you'll find 2 sets of information: Letters/numbers that indicate the build date and usage code, plus a VIN derivative.
Old Nov 6, 2012 | 11:06 PM
Islander21's Avatar
Islander21
I was told by the dealer that factory air conditioning was only available in the coupe model with with the L39 engine for 1966 model year but would like some confirmation on this,
yellow line is at 50, orange line 53 to 55... redline isnt there, the dash instrumentation is the big block variant I'm pretty sure, confirmation needed... please see https://www.dropbox.com/s/0m30gedlge...2019.33.23.jpg
and it does have the sway bar...
battery is on the drivers side near the power brake unit but under the wheel well, the battery is red in this picture https://www.dropbox.com/s/b2yj5ukrwi...2013.23.23.jpg
What we are trying to tell you is that ALL that stuff can be replaced/faked. There is no certainty what you see in the car now is what it started out with.
About the L39, ehm, I don't see that as an engine option for 1966. For the 327s I see base (300HP)and L79 (350). For the big blocks I see L36 (390HP) and L72 (425HP). According to Noland Adam's bible, air conditioning, option C60, was not available with the L72, otherwise it was fair game for all other engine/body style combos. Dealer steered you wrong on that one.
I do find a mention in Noland's book regarding ECL AG (on your trim tag 414AG) It indicates an air conditioned coupe with base engine and a 4-speed. That would also match the redline on your tach and your 80lb oil gauge.
Old Nov 7, 2012 | 02:42 PM
JohnZ's Avatar
JohnZ
Unless you have a lot more mechanical and restoration experience than it appears, I'd pass on that car and keep looking - it's pretty close to a basket-case/rust-bucket, and it needs EVERYTHING.
Old Nov 7, 2012 | 06:11 PM
A-Snake's Avatar
A-Snake
+1,
Old Nov 7, 2012 | 06:41 PM
62Jeff's Avatar
62Jeff
I don't think he needs buying advice, I think he already owns the car.
Old Nov 7, 2012 | 07:01 PM
A-Snake's Avatar
A-Snake
Originally Posted by 62Jeff
I dunt think he needs buying advice, I think he already owns the car.
There is a old saying about vintage cars, "Fill your library before you fill your garage" ;-)
Old Nov 7, 2012 | 07:46 PM
Mark_Milner's Avatar
Mark_Milner
While you are taking pictures, here's a list.
1. Engine bay
2. Battery location
3. Fuel pump area
4. Engine stamp pad on front of block, passenger side
5. Radiator with where it goes to the inner fenders
6. Firewall
7. Frame under the doors, both side and in both forward/rearward directions
8. Overall of car
9. Overall of interior
Old Nov 7, 2012 | 09:00 PM
hzz's Avatar
hzz
I think you're right.
Unfortunately
Old Nov 7, 2012 | 11:16 PM
Islander21's Avatar
Islander21
thanx for this info... [what does ECL AG mean?]
I was told [by someone I cant remember ATM] that the 80lb oil gauge was for the L36 390HP base variant... could this be true?...
even if it was, it still sounds to me that this was a factory 327 350hp with perhaps a changed up dash...
I had a long hard day on the road so I didn't get the chance to photograph the numbers discussed earlier on the block...
I should be ready to do the work needed by tomorrow and will post the pictured results then for ya'll to discuss with me then...
Friday I have a long haul south to Vancouver and wont be able to play with the baby monster till i get back next Wednesday...
ECL is the Exception Control Letter code, it identifies options on you car and it is part of your TRIM code - the last two characters/letters in your case. 414 identifies your interior as bright blue vinyl, AG identifies it as I mentioned previously.
Well, I actually meant to type 60lb, not 80lb. 60 is what I think I see in that fuzzy picture. The 80lb oil pressure gauge deal is dicey. It is said they were meant for use in the L72 425hp big blocks, but there is evidence they were also used in L36 390HP cars and some even found their way into 327s. Either way and it's a simple item to replace regardless. My best guess is your coupe was born with AC, the base 327 300HP engine and a 4-speed.
Old Nov 8, 2012 | 08:27 AM
DansYellow66's Avatar
DansYellow66
I would keep researching. That car may have been molested some time in it's life - but if so, it was a ways back. The rear sway bar is an easy addition but it looks like it has been there awhile. And trying to look at the rear suspension picture it looks like the differential could have big block u-joint caps on the half shafts at the differential. It's too blurry when blown up to be sure. And without checking my Noland Adams book, didn't 427/390 cars with AC have the battery on the driver's side? I may be remembering this incorrectly never having a C2 with air. Also, the front coil springs do not look like small block stock springs to me. They look like they could be a BB spring - no way to be sure without removing them for closer examination or finding remnents of the tags on them. Also, springs are one thing that do get changed out over the years.
Over 45 years a lot of things get messed with on these cars that have gone through a number of owners.
To VIN Help
Old Nov 8, 2012 | 08:52 AM
AOS_L79's Avatar
AOS_L79
Here's a link to more photos of the car.
http://www.ebay.ca/itm/ws/eBayISAPI....d=408301395678
I think it's restorable, but I don't know how the seller could claim the body is in 'real decent shape'. Those look like expensive repairs to me.
Old Nov 8, 2012 | 10:48 AM
DansYellow66
It has a BB radiator and hood suport on the driver side. That is another sign it could be originally a 427/390 car. Rear wheel openings have been trimmed out. They would have to be lived with or repaired. No sign of rust around the door opening gutters which is a good sign. Hard to tell what the paint may be hiding. The apparent body damage is not too bad if you're handy with fiberglass repair. It's what you can't see that could bite you.
Old Nov 8, 2012 | 07:32 PM
DansYellow66
The hood was shared by the L36 and the L72 cars - no difference. I would agree that as far as can be told from the photos, the frame looks pretty good - just dirty and surface rust. It certainly doesn't appear to have flaking rust.
