which wiring harness should I buy?
Old 11-11-2012, 10:18 AM
alexandervdr
alexandervdr's Avatar
Default which wiring harness should I buy?
I ......
I need to ....ne without aircon?
Last edited by alexandervdr; 11-11-2012 at 10:30 AM. Reason: got posted twice, don't know how to delete a thread...
Old 11-11-2012, 11:47 AM
5thvet
5thvet's Avatar
Try Lectric Limited. That where I bought all of mine with a great fit. I know others have used M&H with the same compliments.
Old 11-11-2012, 12:26 PM
alexandervdr
I know, my original question was if I need the one WITH or WITHOUT aircon if the plan is to install a vintage air aftermarket aircon.
Old 11-11-2012, 12:27 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
Call the manufacturer of the airconditioning system you plan to install. I have to believe they design their systems on the basis that the car in which it will be installed, does NOT have the A/C wiring harness.
Old 11-11-2012, 02:38 PM
macs65
macs65's Avatar
I bought an Lectric harness. I beleive that the aircon harness fits the Alt on the D/S and the harness without air requires the Alt to be on the P/S.
Old 11-12-2012, 09:30 AM
alexandervdr
I did ask Vintage Air directly, and here is the answer. (very fast, within a day!)
"The one w/o AC would be fine - the Vintage Air system comes with its own
wiring harness that will connect the power and ground directly to the
battery and one "key on" wire that will go to your fuse block or ignition
switch.
Vintage Air"
Old 11-12-2012, 09:48 AM
alexandervdr
If that is correct, it depends on where the alternator is mounted. If I am correct, if AC equiped (VintageAIr and others) this is on the DriverSide, so harness to use is the one for aircon.
Old 11-12-2012, 01:25 PM
macs65
macs65's Avatar
I do not have A/C , but I beleive A/C is routed on the P/S.
Prior to installing the new wiring harness my Alt was located on the D/S. When I ordered the harness I just ordered the one listed as "except A/C". I had to relocate the Alt to the P/S to connect the wiring. Not a big deal.
To which wiring harness should I buy?
Quick Reply: which wiring harness should I buy?
