Electrical Question 65 Coupe
Old Nov 13, 2012 | 09:40 PM
Silvette00's Avatar
Silvette00
Default Electrical Question 65 Coupe
With the headlights on, I keep blowing the dash light fuse ( and of course the taillights too), If I turn the dimmer control very low,it does not blow the fuse. If the lights are off, no problem. Any ideas?
Old Nov 13, 2012 | 09:43 PM
62Jeff's Avatar
62Jeff
Pull the fuse and measure the amperage at the fuse holder with the headlight **** turned all the way to brightest.
Does your car have factory A/C?
Have you changed anything recently?
Is this a new problem?
Old Nov 13, 2012 | 09:57 PM
Silvette00's Avatar
Silvette00
Default 65 coupe electrical robes
I have had the car only a few weeks and have not driven it at night until last evening. It is a factory air car, but of course the ac was not on with the recent dip in temps here.
Old Nov 13, 2012 | 10:04 PM
62Jeff's Avatar
62Jeff
Ok, if you can pull that Panel Lamps fuse and measure the amperage at the fuse holder with the lights on, that will tell us a lot about how much draw you have.
The fuse is normally a 4 amp fuse. This circuit was in place in 1963 as a 4 amp fuse.
In 1965 - 2 more panel lamps were added to the cluster. Plus the A/C cars had 2 lamps around the clock. Thus a 65 with factory A/C has 4 more 0.33 Amp lamps than a base 63 does - and yet still uses a 4 amp circuit.
If the lamps are new, or someone put in brighter ones, you may be pulling more than 4 amps now.
I went through this several years ago with my 65 and had to put a 5 amp fuse in the circuit (on the recommendation of the wiring harness manufacturer) AND had to replace the stock bulbs with slightly dimmer ones. Here was my nightmare http://forums.corvetteforum.com/c1-a...ort-still.html
Old Nov 13, 2012 | 11:35 PM
65GGvert's Avatar
65GGvert
The tail lights should not be fed by the same fuse as the dash lights. They use a 10a fuse just below the 4a fuse for the dashlights. If blowing the 4a fuse kills your tail lights, something is wired wrong. When you turn the dimmer, do your tail lights dim also?
Just to clarify, the second fuse from the bottom, marked "tail lmps" should be a 10a. The third fuse from the bottom should be a 4a marked "instr lmps".
Old Nov 15, 2012 | 04:24 AM
65GGvert's Avatar
65GGvert
Any update?
Old Nov 15, 2012 | 10:35 AM
watson's Avatar
watson
I had a somewhat similar problem on my 65. After chasing it for a while, I found that the problem was corrosion in the firewall connector. When I cleaned that out, everything was fine. Just a warning, disconnect the battery before you try to clean that connector. Don't ask why I know that.
Doc
Old Nov 15, 2012 | 06:23 PM
65GGvert's Avatar
65GGvert
Did anything here help with the problem? Would be nice to know for future questions.
Old Nov 20, 2012 | 08:02 PM
Silvette00's Avatar
Silvette00
Default Reply
Thanks everybody for your advice, sorry for the late reply, work has been a bear lately. I finally got around to putting a slightly larger fuse in the dash light slot, the smallest I had is a 7.5 amp although I need to te to the store for a smaller amperage. So far so good, taillights work fie and don't dim when I turn down the dimmer.
Old Nov 20, 2012 | 08:13 PM
70mph@2200rpm's Avatar
70mph@2200rpm
But still, that doesn't answer the question proposed in post #5...
To Electrical Question 65 Coupe
