Dwell setting question
Old Nov 16, 2012 | 07:54 PM
Tinat's Avatar
Tinat
Default Dwell setting question
What is the procedure of setting the dwell on dual point dist. with fuel injection?
Does the dwell meter connect to plus and minus side of coil?
This is the 1960 corvette.
Old Nov 16, 2012 | 08:30 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Hi Junior and Tina,
Connect the "hot" lead of the dwell meter to the (-) terminal on the coil. Connect the other dwell meter lead to a convenient ground point.
To set the points, disable one set by jamming a piece of cardboard between the contacts. Run the engine and adjust the other set of points for 29 degrees dwell.
Now, move the cardboard over to the other set of point contacts and set the first set of points for 29 degrees dwell.
Remove the cardboard (which enables both sets of points) and verify that you've got about 33 degrees (as I recall) total dwell.
Having said that, I find dual points to be a PITA. So in the distributor of my 'FI '60, I have one point set disabled permanently. Runs fine.
Jim
Old Nov 16, 2012 | 08:44 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Its actually 34* total dwell as the final measurements; but Jim is right on the rest..here is the procedure:
http://chevy.oldcarmanualproject.com...2csg06y05.html
The dual points supposedly provide greater coil saturation via the extended dwell....
I pulled my dual point dizzy and run a Pertronix billet distributor.
Old Nov 16, 2012 | 09:30 PM
Tinat's Avatar
Tinat
Thanks Jim, I just lost memory on this. I had the car running great and the cranking signal valve went bad and fouled out the points and plugs. I was told this might happen often.
Anyway, once again, thanks !!!!!
Old Nov 17, 2012 | 08:34 AM
Avispa's Avatar
Avispa
Indeed that was the reason. It is necessary for the points to open to a certain minimum gap in order to break the arc that forms when they open. If the gap is too small, the arc will never break, and you'll get almost no spark. That's why you can't just crank up the dwell by closing the gap on single points. If you aren't having the car judged, for heaven's sake get something electronic, preferably something that fits in the distributor. There are in-distributor units available with only one hookup wire so that it will even look like you have points in there if you want to keep the appearance original.
Old Nov 17, 2012 | 04:14 PM
bluzrocker's Avatar
bluzrocker
I wouldd like to know about the dizzy that will work (electronic) that will fit under my BB shielding...pls
Bluzrocker
Old Nov 17, 2012 | 04:19 PM
JohnZ's Avatar
JohnZ
Bluzrocker
Your stock distributor with a conversion kit (Pertronix, Breakerless SE, etc.).
Old Nov 17, 2012 | 04:31 PM
bluzrocker's Avatar
bluzrocker
Tx for the reply...but I need a complete dizzy any suggestions or prefrences?...I have a 427/435 and would love to have a stock TI etc...but.... I think there is something that Forum members might suggest and the source..would be appriciated..and still work under stock shielding
Bluzrocker
Old Nov 18, 2012 | 08:13 AM
Avispa's Avatar
Avispa
Bluzrocker
This one:
http://www.summitracing.com/parts/maa-3864501/overview/
Old Nov 18, 2012 | 08:37 AM
Frankie the Fink
Army
Originally Posted by Avispa
Pertronix has a similar offering with their Ignitor III billet distributor and it includes an internal rev limiter. Either should fit under ignition shielding although you may have to 'reclock' the plug wires to get the best fit. This is what I run.
Old Nov 18, 2012 | 09:21 AM
62Jeff's Avatar
62Jeff
No tach drive on the Pertronix.
Old Nov 18, 2012 | 10:52 AM
Frankie the Fink
Army
True - forgot it was F/I !
Old Nov 18, 2012 | 10:58 AM
62Jeff's Avatar
62Jeff
It's worse than that - the reference to the Summit link was for Bluzrocker, who has a 427.
To Dwell setting question
