327 head question
Thanks,
Bob
Doug
Without screw in studs these will be of the 1.94 variety....still very good....the 2.02's did nothing for flow because GM never opened up the bowl area to make any improvement in flow.....
These are great heads ported.....all double hump castings had the same ports.....with the exception of a few....
These fetch between $300-$500 on ebay....
Peace,
Jebby
Peace,
Jebby
Jebby
Peace,
Jebby
If they are factory 2.02/1.60 heads then the intake valve was unshrouded from the factory.
All double hump heads had (approx) 160 cc intake ports, except the 461 "X" heads which had (approx) 170 cc intake ports.
If one is careful, and the heads have minimal core shift, then the intakes (chambers) can be further unshrouded and the intake ports opened to more than 183 cc. They will flow more than 260 cfm @ .600 valve lift with 2.02/1.60's.
The 2.02's were cut a little bigger...but it did almost nothing as the big sharp edge
around the bowl was never blended.
I was aware of the X head...that is why I mentioned almost all.
There is potential for the 462.....mine flow 244@.500.....I did not open the valve
further during the test. A lot of work to get this....
180 + cc is right.....and unshrouding the chamber to the bore scribe is free horsepower!!!!
Triple black.....what heads did have screw in studs....always thought that was part of the L79 package....
Jebby
Jebby
I believe that screw in studs and guide plates started with the 1970 Z28 and LT1, both of which used the 3927186 cylinder head.
Do you have 2.02/1.60 valves in your heads? I ported mine to 185cc and did one little trick to the chambers, despite reading and being told not to do it. It was good for more flow and that's probably why they flow better than 260 @ .600 lift. This is not achievable unless you are working with 2.02" intakes. Exhaust ports flow better than 200 @ .600 lift with 64cc ports.
Bob
The exhaust seats were a bit pounded....so I opened them to 1.60
The intake I left alone....but the Serdi had a five angle cutter on it and I carefully
blended this in at the bowl....Chamber around intake was bore scribed and pulled back
to unshroud it....gasket matched but left the port rough along runner to help with suspension......
My heads are not the ones that came with the car obviously....but I wanted to keep a "period" look so 2K went into those heads.....
I kick around throwing some Dart platinum's on it but it looks almost stock and runs great.
To our OP.....post them on E-Bay.....you won't break any records but $500 is nothing to sneeze at
Jebby
NO screw in studs/guideplates (from the factory) until the 1970 model LT1 (370hp) Corvette engine or the Z28 (360hp) engine. ONLY BBs had them before 70.
And, as an additional note, as pointed out above, almost any double hump head can be gently worked and opened up for larger valves which will dramatically improve flow and performance-----------------it's only money!
BUUUUUUUUUUUUT, be DAMN careful when buying an unknown set of heads from an unknown source. The NEWEST double hump head (with NO threaded holes in the ends) was a 68 model. It is moderately common for these heads----------------ESPECIALLY THOSE WHICH HAVE SEEN SEVERE DUTY---------------to have cracks around seats, between seats or near the center ex ports which is the area where the most heat occurs. Personally, I WOULD NOT buy a set without first having my machinist check and magnaflux them.
Tom Parsons
