worked on the car today and tried to bleed the brakes with no luck. so took off the drivers side rear wheel and saw why. the caliper is leaking just a tad. that is the only one leaking. so off to get it rebuilt.
I also had stainless calipers. Had one that leaked. Checked it with all the others and found that the casting wasn't true. Leaked by the O-ring. Ordered a couple of new ones and had one of those leak at the hose connection at the caliper. Checked it out and found that someone had put a large indent in the seat where the brass seal goes. Called VBP and they sent me a new one. I shipped the old one back so they could verify the problem. Good luck on getting yours fixed.
