Timing light?
Ben
I switched to the CP7529 Digital Dial-Back and it always runs flawlessly. I got the best price on line and Amazon delivered it for free.
I have an Actron manual dial-back and it works fine. I also have a Harbor Freight dial-back and it also works well, at about half the price.....but I have only used it 2 or 3 times so I can't speak for it's longevity. Stay away from Sears.....they are not what they use to be. I paid 60 dollars for one, and it quit working after only a couple of uses, and man are they heavy.....drop it on your fender, and you have had a bad day.
I have an Actron manual dial-back and it works fine. I also have a Harbor Freight dial-back and it also works well, at about half the price.....but I have only used it 2 or 3 times so I can't speak for it's longevity. Stay away from Sears.....they are not what they use to be. I paid 60 dollars for one, and it quit working after only a couple of uses, and man are they heavy.....drop it on your fender, and you have had a bad day.Agree........they are heavy. I also found that if I stored it out in the garage with high humidity, the dial back feature would become erratic after a year or so. I assumed that it was due to corrosion on the dial **** contacts. I now store my new/replacement Sears Actron timing light inside the house.
Larry
You don't even need to route it normally, just run it from the cap to the plug and when you're done reinstall the MSD wire that you left (unconnected) in place.
I have a Snap-On dial-back that has worked fine on every vehicle I've used it on, but I can't say I've tried it on MSD wires either.
Good luck... GUSTO
P.S. I have a friend that has an Equus Pro timing light and I've used it in the past on much more than regular carbon core wires and it always worked superbly. I intended to buy one myself until I stumbled across a good deal on a Snap-On light.
Good luck... GUSTO
Ben
Well.........yes and no. The wires in themselves don't make the difference, but the spark plug gap does. It depends on whether your ignition system design requires them, or not.
Try this experiment just for shlts and grins:
Gap your spark plugs at .045". You'll almost certainly have to temporarily install a high energy coil because your standard coil will not consistently fire your plugs with such a wide gap. Drive the car normally for awhile and bring engine speed up past 5500 (6500 with solid lifters). Don't be concerned with the misfiring..............it's normal under these conditions.
Take the car home and let it run when ambient lighting is very low. Notice the sparking/leaking that is probably occurring, especially in places where the 7mm wires are near ground, or any places where nos. 5 & 7 are in proximity of each other. Did you ever wonder why auto manufacturers began using heavily insulated ignition wires once they began using high energy ignition coils?
BTW-we don't see you on the VH board much these days.
Oddly......................or not........................the ability to light off those pesky lean mixtures provide distinct advantages to old school (dirty) high performance engines as well. Wide plug gaps require higher voltage to bridge and therefore create a fatter, hotter spark which promotes more complete and consistent combustion. It ensures more complete combustion at high engine speeds and very high cylinder pressures experienced by engines designed with very high DCR's. It also helps fire plugs that have been either gas or oil fouled, in most cases.
Does VH mean "Valhalla"? In Norse mythology, Valhalla (from Old Norse Valhöll "hall of the slain") is a majestic, enormous hall located in Asgard, ruled over by the god Odin. Chosen by Odin, half of those who die in combat travel to Valhalla upon death, led by valkyries, while the other half go to the goddess Freyja's field Fólkvangr. In Valhalla, the dead join the masses of those who have died in combat known as Einherjar, as well as various legendary Germanic heroes and kings, as they prepare to aid Odin during the events of Ragnarök. Before the hall stands the golden tree Glasir, and the hall's ceiling is thatched with golden shields. Various creatures live around Valhalla, such as the stag Eikþyrnir and the goat Heiðrún, both described as standing atop Valhalla and consuming the foliage of the tree Læraðr.
All true, but really not applicable to any but a minute percentage of people that have 'racin' motors. No tangible benefit to the rest of us.
I'm sure you'll disagree.
